20 Most Recent
HP Deskjet D1430 InkJet Printer Questions & Answers
My printer prints blank pages. No writing.
Hi
Did you try replacing the print cartridges?
Try to replace and check. If u are sure that is has inks but does not print then you need to clean the nozzles with warm water.
Take a dump cloth and wet it with water and clean the print nozzles on the cartridges
My printer just prints blank
You should use the HP software (that I assume you probably have installed on your PC) to see if there is any ink left in the printer cartridges. This may sound silly if it is a new printer, but I had an HP printer ship one time with faulty color ink cartridge.
If it is not an empty cartridge, I highly recommend lifting the top of the printer to reveal the ink cartridges. Take them out, and carefully place and seat them back in. Many times incorrectly installed ink cartridges causes printing problems. Hope this helps.
Thanks for using FixYa
Have hp d1430 printer, I only use the color print
YOU SHOULD USE HP 21 BLACK INK CARTRIDGE FOR BLACK PRINTING.IF YOU USE 22 COLOUR CARTRIDGE YOU WILL GET ONLY GREAY PRINTING ONLY.I AM RIGHT?IF YOU USE COLOUR CARTRIDGES MAY YOU WILL GET MONEY LOSE. BECOS IT WILL FINISH EARLY.BLACK INK COST IS LESSTHAN COLOUR INK CARTRIDGES. SO YOU SHOULD BUY BLACK CARTRIDGE FOR REAL BLACK PRINTING.
I have a HP Deskjet1430
Hi There and Welcome to Fixya!What you need is a software driver for this Deskjet to "communicate" with your computer. I have included the website where you can download the installation files. Please note that this came from HP's support site :
HP Printer DriverThe next thing that you need to ensure is to choose and click your operating system then choose "driver". Wait for it to complete then open the folder where the files are downloaded and let the driver installation initialize. (Make sure that your printer is connected to your pc and turned "on" before taking any of the steps that I mentioned.)Follow the onscreen instructions until the installation is complete, restart your PC, and you should be good to go! I hope this helps, and Thank you for using fixya.
My printer won't print a test page - how do I stop
Hello
Thank you for using FixYa for your problem
Power light blinking for a reason, a error.
have to work out why now and what error is showing. Try unpluging for a few minutes and restarting the printer, the startup mode can clear some errors
Please rate our solutions and if you still have problems please call back for more ideas to help you
Thanks
Richard Scott
Technical Support
New Zealand
It just started blinking and says the printer is
If it says printer is offline, it usually means your printer is not connected to the PC. Blinking printer light means there is a problem with the printer (usually paper jam) or with the ink. Check the ink cartridge. Take the cartridge out and put it back in. Make sure you also check the USB cable that goes from your printer to the PC, take it out and put it back in. Also, try to turn off the printer, take it out of the power outlet for 30 seconds and put it back in. If you have a power strip, don't use it, try plugging it directly to the power outlet on the wall and turn it back on.
I am out of colored in for my HP Deskjet D1430 and
Yes, right click on the HP icon, located on the bottom toolbar, next to clock, and exit. The HP software is what's harrassing you. You will need to do this everytime you boot computer but it is worth it.
Wont print
Normal
0
Disconnect
the printer or at least be sure it is turned off. I'd do both and
reinstall the CD software program that came with the printer. When the
software program asks you to connect the printer to the USB port, do so and it
should again work properly.
Hope
this helps. Bud
