20 Most Recent Dell 1320c Laser Printer Questions & Answers
3answers
Dell 1320c printing error "no paper detected"
I had the same problem. I removed the paper tray, turned the printer on its side and manually moved all the working parts on the bottom of the printer - rollers and switches..
When I reinserted the paper tray, everything worked fine.
PS. I ordered and returned a new paper tray from Dell, that was not the problem.
2/9/2022 4:47:32 AM • Dell 1320c Laser... • Answered on Feb 09, 2022
5answers
My dell laser printer 1320c has printer error code
this error means
Replace DrumCart
091-935
Drum Full of
Waste Toner
The drum cartridge needs to be replaced. fro more information about how to remove it you can got to following link
http://support.dell.com/support/edocs/systems/3100cn/en/UG/section22.html#172399
12/2/2021 7:23:23 PM • Dell 1320c Laser... • Answered on Dec 02, 2021
11answers
Black is faint. All other colors good. Dell 1320C
I have just got around this issue by going into the printer properties, click the "Printing Properties" button, click the "Printer Status" button, go to the "Printer Settings" screen select the "Printer Maintenance" tab, select the "Non-Dell Toner", tick the Non-Dell Toner box and click the "Restart printer to apply new settings" button. Print a test and then reverse the process.
6/22/2020 7:58:53 PM • Dell 1320c Laser... • Answered on Jun 22, 2020
Need to download a service manual where can i download a service manual for a Dell laser printer 1320c
Apparently others have tried to obtain a service manual for that model, and one was not available. Frustration was expressed, but it did not result in obtaining a service manual for that model. https://www.dell.com/community/Printers/1320c-Service-manual/td-p/5112626 Other sites might have some solutions for problems with that model, even though not a service manual. Example: https://www.dell.com/support/article/us/en/04/sln153516/replacing-the-phd-unit-on-1320c-2130cn-2135cn-2150cn-2150cdn-2155cn-2155cdn-dell-laser-printers?lang=en Here is another approach to try for repairing it. Perhaps a service manual for a similar model, since your is from 2013, would be helpful. Since the link above from Dell shows other model numbers using a similar part replacement so maybe service manual for one of them could be located: 2130cn 2135cn 2150cn 2150cdn 2155cn 2155cdn 2130cn service manual from 2010: http://www.refurbisheddellprinters.com/content/manuals/service/Dell%202130cn%20Full%20Manual.pdf 2135cn service manual from 2008: http://www.refurbisheddellprinters.com/content/manuals/service/Dell%202135cn%20Full%20Manual.pdf 2150cn service manual (registration required to download) https://www.scribd.com/doc/202253581/Dell-2150cn-Service-Manual Miscellaneous service manuals: https://www.mpsprinters.com/categories/dell-service-manuals.html?sort=pricedesc&page=2 Sorry to put so many links, but perhaps one of these will help solve problems with that printer.
11/20/2019 1:36:29 PM • Dell 1320c Laser... • Answered on Nov 20, 2019
2answers
Dell 1320c prints black as light grey. Tonor
This isn\'t a fault with the printer, IT IS A FAULT WITH THE WAY IT HAS BEEN SET UP! The problem is, not all of the tabs have been removed from the PHD unit inside. In order to remove these, you need to open the front cover of the printer, move the four tabs 90 degrees and pull the whole PHD out. You will then see the four yellow tags on the side.Having printed with the tags in means the PHD has been potentially damaged. If you\'re lucky, you\'ll get away with removing the tags now and it will return to normal after about 50 pages, it not then you\'ll need a new PHD. The reason the problem manifests itself with black first is because the black is the most commonly used colour.For info on removing all the tags, see here:http://support.euro.dell.com/support/edocs/systems/prn1320c/en/ug/1320c_en/section04.htm#1055182
11/5/2019 6:13:32 AM • Dell 1320c Laser... • Answered on Nov 05, 2019
3answers
1320c Dell Printer has blinking orange error
If the light is flashing, it might not be the PHD, but you might be having a problem with the PDL emulation. Just go the control panel, right click the Dell printer. Select printer properties, not properties. Go to the advanced tab and check print directly to printer instead of spool print documents. This should work.
10/31/2019 12:22:29 PM • Dell 1320c Laser... • Answered on Oct 31, 2019
2answers
My dell 1320c only prints first3 pages of a pdf
I had this problem with open office text files - the solution was to change the Page format (go to Format>Page) and set the page format to A4.
7/26/2019 11:44:47 AM • Dell 1320c Laser... • Answered on Jul 26, 2019
Black Ink Faded
Perhaps the print head needs cleaning.
10/7/2017 7:28:03 PM • Dell 1320c Laser... • Answered on Oct 07, 2017
Dell 1320c won't recognize new toner
It's possible to be the chip failure. Try to change the chip or reset them (using an chip reseter). Also you can search for service manual on the internet. In the manual you can find more possible causes of your printer failure and how can repair it.
3/24/2017 6:20:04 PM • Dell 1320c Laser... • Answered on Mar 24, 2017
Dell 1320c printer jam
Your paper is probably stuck in the fuser. Open the front, top of printer. There are two blue tabs on either side. You have to remove the fuser and gently pry the paper with your fingers. It's probably crunched up like an accordian. Don't use any implements and don't touch the fuser. GENTLY is the key here. This probably happened because the paper was too thick or you were printer a full page of ink and the paper got sticky.
8/10/2016 8:49:15 PM • Dell 1320c Laser... • Answered on Aug 10, 2016
Cannot print to Dell 1320c printer
check printers on computer select your printer as default
5/2/2016 8:58:46 PM • Dell 1320c Laser... • Answered on May 02, 2016
Dots are printing down the right side.
We are experts to help you for this Call Alex Walker Call +1(404)981-1535
11/16/2015 7:55:01 PM • Dell 1320c Laser... • Answered on Nov 16, 2015
How do I clean my
Hello, You can take a small vacuum and get the toner out then take a damp paper towel with alcohol on it and wipe, make sure the towel isn't dripping. Be sure and take the toner cart. out before you clean. Please rate my answer, Thank you.
11/2/2015 6:25:45 PM • Dell 1320c Laser... • Answered on Nov 02, 2015
Turns on but won't print
Ardyrhe Lantz, We need more information in order to resolve the issue with the printer. Have you installed the correct Driver for the printer into your system. Click the link below to download the online printer manual. http://www.dell.com/support/home/us/en/19/product-support/product/dell-1320cn/research Thank You, Dell-Jesse L Dell Social Media and Communities
4/21/2015 2:01:39 PM • Dell 1320c Laser... • Answered on Apr 21, 2015
I have a Dell 1320c printer and there is a part that I need to replace but I have n idea what it is called. When you open the front it is on the very top. It is the last roller the paper goes through
the last set of rollers are fuser rollers you have a heat roller and a pressure roller the pressure roller is made of rubber and the heat roller is made of aluminium.from the your question im guessing that the paper is wrapped around the heat roller. if this roller has scratches in the serface it does need replacingalso if the pressure roller is damaged it also will cause a papetr jam. also you should check that all of the picker fingers are all in place and clean. I’m happy to help further over the phone at https://www.6ya.com/expert/geoffrey_a52be3eb7822ef96
2/13/2015 5:13:51 PM • Dell 1320c Laser... • Answered on Feb 13, 2015
Change power setting on dell 1320c
For any of your dell printer support, the following link can assist you. It included the mannual, drivers and even FAQ's! Product Support Dell US
1/17/2015 7:48:59 PM • Dell 1320c Laser... • Answered on Jan 17, 2015
Dell 1320c Laser Printer Logo
323 questions posted
Top Dell Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
Norman Weimar
Norman Weimar
Ngoro
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Dell Office Equipment & Supplies
Most Popular Question
dell 1320c printer part need replace but
  • Office Equipment & Supplies
