20 Most Recent
Pioneer Elite PRO-111FD 50 in. Plasma TV Questions & Answers
Pro-111fd 8 RED blinks
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. Viewing it in "
Mosaic" or "
Magazine" will make surf easy.
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Do a search by type in the brand name of the device to the search box.
Sanyo tv model dp50747 keeps shutting off automatically
Short circuited PCB inside it. Any one printed circuit board will have short circuited component/s; in turn draws tremendous current during switch-On, and the short circuit protection circuit inside the TV activates, and shuts it down, is happening now. Contact any service technician, or authorized service centre for Panasonic. This is not a user repairable fault.
If you wish to get some details; check the site linked here. Viewing it in "
Mosaic" will make surf easy.
Pioneer 5020 will not power up and blue light flashes 8 times
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power led, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating, to many popular brand TVs and other devices. Viewing it in "
My Pioneer Elite PRO-111FD just
Check your power source (electrical outlet) and the power cable. If electrical outlet is ok, try using a different power cable (the cable that you plug on to the electrical outlet going to your TV set). If everything is ok but still no indicator light, call your technician there might be a problem with the TV power supply.
Pioneer plasma stopped display
The TV Guide feature is active even when the zip code is set to all 0s so if you have an over the air antenna attached the TV will look for the TV Guide info and if it can not find it because of a weak signal or the chanel it is tuned to does not carry that information the TV thinks that tuner does not work which triggers the 12 flashes. Also on power up the gray box with the waring message "Plasma Display Starting Up, Please Wait" appears and the screen is blank. .Un plug the power to the Plasma Screen and also to the Media Receiver for ten minutes. Disconnect the off the air antennas both A and B. After ten minutes plug in the plasma screen then the media receiver and turn on with the remote control. You should now be back in operation.
If Problem still Remains, There are two cables that go from the media center to the Plasma display. One is the video/audio signal, the other is control/communications with the between the two units. Power off both units and remove the power (from the wall) and double check that the cables are fitted not loose - even removing and then reconnecting could rectify this problem.
If that does not correct the problem, there may be a power supply problem with the Media center on its boot up. This will then need to be serviced.
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Picture off
Is your TV connected to a cable box or satellite? Please check the physical connection first, it could only be a loose connection or connector for the TV out.
TV keeps shutting off automatically
Since your plasma is less then a year old, I would suggest to contact the manufacturers to get it fix under warranty. If the plasma keeps shutting off by itself, that is not normal and should be repair.
