20 Most Recent
Proscan 32LA25Q 32 in. LCD TV Questions & Answers
No signal from my dvd player
Can you tell me how to connect my dvd player to my 42 inch proscan hdtv ? There are no yellow,its blue and there are two rows of the same colors.
How do I connect a WII to this TV?
plug the red and white and yellow plugs into the AV input on the back of the TV rather than the component in on the TV. (they look very similar easy to confuse)
Proscan 32la25Q Backlight not comming on
You either have a faulty backlight or one or more of the inverter transformers is bad,
a close inspection of the picture when on will show a bad tube as it will be lighter or darker than the rest,transformers may be hot to the touch
Len..
Wont turn on
If there is no standby light, it means that the main power supply regulator board to this TV, does not get AC power at all, or there is some fault with it. It will be best to contact any service technician. If
you wish to get more details, check this link.
http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic
/Timeslide, can be selected by the drop-down list, by the top left
of the display window, will make surf easy. You can also do a search, by type in the brand name / model
number / IC used, in the search box at the top right of the display window
Will not come on. Has power from the outlet....
mine did the same thing finally i tryed unpluging it from back of tv well still plugged in and then pushing in the power button on the tv and mine turns on but i cant use a remote to shut it on or off and cant seen to find any info on this tv anywhere so for last 3 months that is how ive been turning it on and off any ideas ??
