20 Most Recent Toshiba 46XF550U 46 in. HDTV LCD TV Questions & Answers
I also have this problem on a set that is a year and a half old. The repair man was here yesterday with some parts that didn't fix the problem...he said the screen needs to be replaced! Luckily I bought from Costco, who extends the warranty by a year, so we won't be out any money. They will be getting back to me with what they are going to do...repair or replace...depending upon what is most cost effective for them. I will be trying to purchase extended warranty for this TV, if repaired, or new TV, if replaced. Too many horror stories out there on all brands not to.
Toshiba 46XF550U... | Answered on Jun 12, 2010
It is out there, that if you have internet enabled on the Toshiba BD player, did you need to stop or disable the internet capability.
Toshiba... | Answered 2 days ago
the power led may be flashing a code you can google.
My Panny will flash the power LED when there is a problem. Well, for many problems anyway. Observe the sequence like 7 and 3. I do not know if the Toshiba has that feature. If not, the issue is most likely power, HOWEVER, any board could be at fault since it powers up then shuts down. An excessive load on another board could be shutting it down. A fault on the PS board itself could also be shutting it down.
Toshiba... | Answered on Nov 07, 2019
It sounds like the main internal power supply has gone south. Your best bet would be to take it into a TV repair shop and determine if it would be an inexpensive repair. Usually repairs on the newer TV's can run higher then replacing the TV with a newer model.
Toshiba... | Answered on Nov 05, 2019
USE ANY NUMBER HERE. CALL A SPAMMER AND HAVE SOME FUN TODAY!! ALL TOLL FREE TOO!!
THIS IS A COLLECTIVE PHONE LISTING OF ALL THE SPAMMERS HERE ON FIXYA. WE SUGGEST YOU DONT CALL ANY OF THEM UNLESS YOU KNOW WHAT YOU ARE DOING !!
1-85O-8I2-4OO9 1-8OO-8O3-1O69 1-888-499-5520 1-877-769-0969 1-888-499-5520 1-8OO-828-O294 888-348-1833 1-888-444-6538 1-855-616-7697 l-855-892-OO6O 1-888-570-9791 1-855-26O-OO64 1-855-536-5666 1-844-24O-9111 1-8OO-55O-5195 1-845-481-1722 1-855-616-7697 1-844-819-3382 1-855-221-4867 1-845-481-1722 1-800-258-1449
IF YOU KNOW WHAT YOU ARE DOING HAVE SOME FUN WITH THESE LOSERS.. CARRY ON7
Toshiba... | Answered on Nov 03, 2019
If your TV is connected to the internet, firmware will be
automatically made available.
If your TV is not connected to the internet, you can download the latest version of firmware from www.toshiba-om.net/firmware.php
www.toshiba-om.net
If you are still having problems contact the Toshiba Helpline on 0333 222 7111
http://www.toshiba-om.net/pdf/manuals/lcdtv/English/Country_Specific/L2436-4050-English-Specific.pdf
Toshiba... | Answered on Nov 02, 2019
Open internal fuse or power supply failure
Toshiba... | Answered on Oct 31, 2019
THERE IS NO RESET GO SEE A LOCAL REPAIR SHOP
Toshiba... | Answered on Oct 27, 2019
You need to check in sound sitting and make sure the audio is set to be from tv not amp
Hi Upul73879, indicates Toshiba TV model, what are you commenting on and what do you want to connect it to, in order to find the best possible solution
I wait your answer
Greetings Franco Dosil
Hola Upul73879, indica modelo del TV Toshiba, que estas comentando y a que quieres conectarlo, para poder encontrar la mejor soluci?n posible
Espero tu respuesta
Saludos Franco Dosil
Toshiba... | Answered on Oct 26, 2019
Contact Toshiba directly to request it.
Toshiba... | Answered on Oct 15, 2019
bad high power board or main control board
Toshiba... | Answered on Oct 10, 2019
go into set up and choose tv air then channel search make sure you have an antenna connected for free tv
Toshiba 46XF550U 46 in. HDTV LCD TV Logo
3 questions posted
Top Toshiba Televison & Video Experts
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Toshiba Televison & Video
Most Popular Question
vertical red line 46 inch lcd 2
  • Televison & Video
