20 Most Recent
Sharp LC22DV24U 22 in. LCD TV/DVD Combo Questions & Answers
DVD won't eject
Manually pull the door open. If you can see the motor spinning in there it may have a rubber "band" that looks like and O-ring. If that is broken then it can be replaced but it is a difficult manuver with a screwdriver. They tend to dry rot like all rubber parts and fail...
Sharp lc22dv24u screws for the stand
The screws for the stand normally comes along with the packing within the carton and if you had lost them these long screws can be procured from a hardware shop. All you have to do is to take along the stand and metal plate along so as to confirm the screw thread.
Playstation 3 will not come
Try resetting the playstation and a hot swap. Turn off the tv and the playstation and remove the hdmi cable from the television. You should see a red standby light on the playstation. Press and hold down the power button until you hear two beeps. Now plug the hdmi cable back in. Turn the television on. Turn the playstation on. Hope this works.
When playing dvds the sounds skips.
First I would check and see if there we any scratches on the disc, if not sounds like a decoder issue inside the
blue ray player what I would do is turn it off wait for a couple min and re power it up if it persist you might need repair is the only thing I
can suggest besides getting a cleaning kit for it.
Thanks i hope this information helps please do click the accept button for my efforts! Btw, I’m available to help over the phone in case u need at
https://www.6ya.com/expert/edwy_1a56970cf1ea4620
SHARP LC-26DV20U
Part called digital unit is your problem, It require technical and soldering skills to replace it.
After lightening storm dvd will not eject from
You could have poped a cap "capcitor inside" or a fuse that controles the DVD side. I would check both. Here is a tip also and maybe this will help out others too "never buy combo units" Why? Well the reason why is you have to open the whole unit to fix one side and there aweful to diagnose, in your case here if you cannot eject it seems there is no power getting to that side of the unit and checking these things mentioned above could help you in further fixing of this unit. Remember if its still under warrentee please seek manufacture advice before opening this unt yourself. Also I personally recommend you get a surge supressor for all your eletronics to advoid this kinda loss. Thanks and don't shoot the messanger here and please rate! Btw, I’m available to help over the phone in case u need at
