20 Most Recent Proscan 26LB30QD 26 in. LCD HDTV Questions & Answers
Why does my picture flash on a proscan 42
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary. Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here.
1/19/2018 10:09:26 AM • Proscan 26LB30QD... • Answered on Jan 19, 2018
Proscan 40" TV from Best BUy - screen freeze, screen goes blank
6/23/2017 1:56:35 PM • Proscan 26LB30QD... • Answered on Jun 23, 2017
Locked out of Proscan tv
If you wiah to get some details then check the below added link. http://electro-medical.blogspot.com/
7/7/2016 6:23:29 PM • Proscan 26LB30QD... • Answered on Jul 07, 2016
Where do I find my link code
Link code for which service provider? See below: CableVision UR2-CBL-CV04 code: 096 Charter DIGITAL code: 0463 Comcast M1057 code: 0463, 10463 Cox COX code: 0463 Direct TV RC23 code: 10463 Dish Network VIP508 code: 720 Dish Network VIP622 code: 720 Motorola DRC800 code: 0463 One for All URC-6690 code: 0464 Phillips PDVR8 code: 115 Phillips PH5DSS code: 115 Phillips PHDVD5 code: 115 Phillips PMDVR8 code: 115 RCA RCU807 code: 135 Rogers DCT3250 code: 0463 Shaw DCT3416 code: 0463 Sony RM-VL600 code: 8043 TiVo HD code: 0091 TiVo SERIES 3 code: 0091
4/8/2016 11:00:50 PM • Proscan 26LB30QD... • Answered on Apr 08, 2016
How do I switch from cable to an antenna
For the Proscan 26LB30QD, first make sure that the input is set to TV. (Use the Input button on the TV (top button on the side) or remote with that function.) Then press Menu (second button from the top on the TV) and use the up/down buttons/arrows to select Setup Menu. Use the left/right arrows to move into the sub-menu. Select the line Tuning Band with the up/down buttons/arrows. Use the left/right arrows to change the signal from Cable to Air. Press Enter (the Input button on the TV) to save the setting. Go back to Setup Menu and find Auto Ch Search to scan for channels. Once you select this line, press Enter and wait for the scan to be completed. Press Menu to exit. I hope this helps. Cindy Wells
12/1/2015 11:59:34 PM • Proscan 26LB30QD... • Answered on Dec 01, 2015
Color on screen is green
The t con board o the tv is faulty. Normally in all the tvs bellow 32 inch the tcon board is integrated to the lcd panel. so you have to go for a new lcd panel. It would a costly repairing. www.electro-medical.blogspot.com
11/2/2015 2:10:44 PM • Proscan 26LB30QD... • Answered on Nov 02, 2015
Does anyone have the tv code for the Dish remote for this tv?
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily. http://remotesearch.blogspot.com/ http://electronicshelponline.blogspot.com/ http://electrohelponline.blogspot.com/ Search the site by type in the brand name of your device, in the "Search box at the top right of the display window" to see the set-up codes to your device, with different brand remote controls.
10/7/2015 12:29:20 PM • Proscan 26LB30QD... • Answered on Oct 07, 2015
DVD LOADS BUT THEN SHOWS NO DISK
Check and replace the laser pick-up unit. Contact any servide technician. 25801172-qo0smykjwjpmzyxlla1t3wpe-2-0.jpg 25801172-qo0smykjwjpmzyxlla1t3wpe-2-2.jpg 25801172-qo0smykjwjpmzyxlla1t3wpe-2-5.jpg
7/30/2015 8:25:14 AM • Proscan 26LB30QD... • Answered on Jul 30, 2015
Need to attch the tv stand back kn the proscan 26inch tv/dvd combo
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/ Search the site by type in the brand name to your device, in the "Search box at the top right of the display window".
7/27/2015 3:27:50 AM • Proscan 26LB30QD... • Answered on Jul 27, 2015
Why am I not getting any picture or sound when I hook up my ps3 to hdmi ports one and two?
The drivers on those particular ports have been loaded yet. From desktop hit "start" then right click on computer then click on "manage". Nest click on "device Manager" when it opens up look for ports with yellow question marks and right click on them and trouble shoot them. Or,, you may have to go down o the bottom of the page and open up some new ports and drivers. Col. Dana Gillespie
11/29/2014 5:26:36 AM • Proscan 26LB30QD... • Answered on Nov 29, 2014
Click on botton, blue lite comes on and inmediatly turns off
Your diagnostic circuit is detecting a problem somewhere in the set and shutting it down to protect the remaining good circuits. Check the power board for fault it is usually the culprit. Look for capacitors with spewed up tops. They may also be leaking a oily like substance (electrolyte) and when replaced will fix it. If not then your problem could in many places. Look at the power board first and see if the voltages are coming off it if the capacitors are OK. If not then nothing else on the board can be fixed. You will have to order another. If I can help with anything please feel free to contact me anytime. Col. Dana Gillespie
11/29/2014 5:15:19 AM • Proscan 26LB30QD... • Answered on Nov 29, 2014
2answers
Proscan tv surround sound hook up
This depends on whether you have digital cable box or not. If you have a Digi Cable Box look for the red/white RCA output and connect this via RCA cable to the Red/White Audio input on your surround.
If just Basic Cable look for a red/white audio output on the back of your televison. connect this to the Red/white in on your surround. Could be called tv in or auxillary.
11/8/2014 1:01:44 AM • Proscan 26LB30QD... • Answered on Nov 08, 2014
How to fix a proscan tv/dvd combo no sound when tv on
Check the speaker/s first. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
10/8/2014 11:18:51 AM • Proscan 26LB30QD... • Answered on Oct 08, 2014
Proscan 26LB30QD 26 in. LCD HDTV Logo
200 questions posted
Top Proscan Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Proscan Televison & Video
Most Popular Question
tv goes off self but turnit back
  • Televison & Video
