20 Most Recent
LG 42LG70 42 in. LCD HDTV Questions & Answers
42LG70 powers on but suddenly no pic
Do you get sound? If sound is also not there, it is the power supply which needs to be looked into. If sound is there, it is the inverter section which needs to be checked.
I would like to remove the pedestal or stand from a LG 42LG70 TV because I want to place the TV on a wall mount.
Usually the safe way to do this is look first at the owner manual but lay set face down on a padded surface so all weight is on the frame around the screen and no weight on the screen itself, exert no downward pressure in that position or screen may be damaged.Usually pedestal is secured by 4 or more screws that may require the back cover of the set to be removed first, to get at---a careful look with it face down will show if part of the pedestal is under the rear cover of the set or not.
LG tv has audio only, no video
did you tried to look in the darkened room just to ensure if their is a white screen. if you could see a very dark screen like almost no backlight the cause could be the t-con board. you can check also the ballast board for screen back light which need to replaced .
Can I use my U.S. 42LG70 in Australia?
Two things to consider which will answer this question.1. The voltage source must be if set from USA 110-120 volts out of the wall outlet (I think it will be but check) and if not you will need a converter that converts that voltage to the USA voltage.2. Since the transmission format in USA is NTSC and it is PAL there you will need a set top box that converts PAL to NTSC.( Google PAL to NTSC converter to see those.)Thats it.
