20 Most Recent
Nintendo DS Lite Black Console Questions & Answers
Only used a few times and the power is on but
The reason the screen isn't showing-up is probably because of runny colors or blotchy colors permanently stained on the screen, even when the Nintendo DS Lite is OFF, my guess is that the liquid crystal display (LCD) is cracked. And also, there are multiple reasons for your speakers not working properly. The main reasons for the speakers not working would be the following;- Something small must have gotten wedged inside of the speakers.
- A type of liquid and/or sticky substance leaked into speakers.
- Lots of pressurized force on upper screen(which could have also caused the damage done to the screen).
What I would recommend is make an appointment with "Nintendo customer service".
Switch on my d.s.i goes to menu try and get on to
My first guess would be to Turn
the power off for a moment and then turn it back on. Repeat whatever you did that caused
the error to occur. If the same message still appears, then the best thing to do would be to register a system inspection with Nintendo Customer Service.
How to fix a ds light when the screen flashes for
This indicates that one of the lcd screens has gone. Depending on which screen flashes it is the opposite screen (the one that doesnt flash) that has gone. Screens can be bought off of ebay very cheaply and are relatively easy to fit. There are some good guides on the internet explaining step by step how to fit new screens.
Hope this helps
I cant get my dsi to play games with r4 card,,even had r4 card downloaded with new games
The DSi has several system updates specifically designed to block flashcarts such as the R4. Check the R4 website to see if they have information on what to do if your DSi has blocked the cart. You might be able to do an update to the R4 to fix it. Another option is to get a different cart that has a work-around built in, such as the "SuperCard DSTwo" which has a small chip inside it that other carts don't have and has a file you can download directly onto the memory card that goes into the cart to update it whenever that happens.
