20 Most Recent
Compaq Presario C700T Notebook Questions & Answers
Dvd rom not reading cds/dvds
I had similar problem on a Toshiba Satellite A30 laptop, I simply had to reconnect DVD drive. It usually loosing it's connection with motherboard and drive is visible in My Computer but it doesn't recognize any discs. If reconnection does not solve your issue you may try to update your DVD firmware and if it won't help replace DVD drive. Good Luck!
Cafe world won't run if
With the computer connected to your network (I assume it's ethernet?) and browser access to internet working, try uninstalling and re-installing cafe world.
Free skype download
You can download the latest ver of Skype from this WEB site.http://www.skype.com/en/download-skype/skype-for-computer/
My speakersare not give sound
have you tried a pair of head phones? Yes? Still no sound? Does the speaker icon show up on bottom right corner in Windows? If it doesn't then maybe all you need is to re install the sound driver. Go to your machine's manufacturer's website for support.
Factory restore
-turn the laptop off and on
-when you see the first screen after pressing the on button press f11
-wait
-once a blue screen appears press space
-once a window appears press advanced options and click factory reset
Changing OS from windows vista to xp
You can install xp on a vista laptop, you will need an xp install cd and you will need to backup your data (it will be erased in the downgrade process). As for the drivers, go to your laptops manufactures site. They will have a support section for your laptop model where you can see if there are drivers for xp. If you have the hardware that will support windows 7, I would go with that. Xp is slow and no longer supported by Microsoft as of April 2014, which poses a security risk. Windows 7 will be supported for a while and is faster and more stable than xp or vista.
Game seems to be extremely slow
It might be due to fault in computer graphics world that's not recommended for the game that makes the script working imperfectly. Glitches in a platform game may show error of invisible wall collision errors, sprite errors, freezes, image problems, and others.So all you have to check your hardware and re-install graphics drivers can fix your problem. Also have a look to game requirements for running on PC platform and can fix your error.If you are unable to fix this problem even if Graphic drivers are up-to-date. Then best and easy solution is to use system utility program PC Fresher
How to restore computer after deleting tomany programs compaq evo150
Depends on your computer. Many computers today come with a recovery partition installed. Otherwise you should have received CD's to help you do that when you bought the computer. If you can tell me your situation I can guide you to the next step. (This assumes your using Windows)
Windows system driver
Need more info to help you. All I can say is it would appear your missing a driver. Install any software that came with any device, (including computer itself) your trying to use and see if that helps. Otherwise provide information.
My toshiba lapop freezes when im on facebook trying to play games
It's probably because of flash player or an api of it. You can try to upgrade your flash player. It might work. Also I suggest you to use Google Chrome for less headache :) also you can try to login facebook and play your gamea on Chrome. It will probably solve your problem
Boot time dose not showing hard disk
Hello,Some laptops will show the hard drive icon light up when the pc start up and then nothing. (not often but I have seen a few) If your system is not booting after a few seconds and no hard disk light flickerring on and off, you ether have a bad hard drive or the hard drive may not be properly seated to the disk connection. As your pc boot up, go into the BIOS and make sure your system is "seeing" the disk. if it not, you may need to replace the disk. If it does see the disk, reseat the disk making sure it is fully connected the disk connector. Reboot your pc. If it does not boot, replace the disk. Good LuckC2Solutions
