20 Most Recent
Toshiba Satellite Pro M300-S1002V T8300 Notebook Questions & Answers
How to reset the password n toshiba satellite m300
If you are referring to the Bios Password on the Sattelite Pro M300, if you open up the ram cover on the bottom of the laptop and remove the RAM, you should see two triangular metal contacts (like an up and down arrow) (.
HOW TO REMOVE BIOS PASSWORD ON TOSHIBA SATELLITE A305 AND C655D <- This video put me on the right track to solving the problem). Unplug the laptop and remove the battery. Hold the power button for a few seconds (this is good practice to try to discharge the circuitry to prevent accidental damage. Also, make sure you are properly grounded to prevent damage to the laptop from ESD). What I did was take a small length of wire (I took a piece of a twist tie without the paper) and tape it across the two contacts. On the laptop I was working on there was plastic covering any other contact points, but make sure that you are not going to short circuit anything else. Then I reinstalled the ram (I had only one ram chip, and unlike the previous video I had to install it in the slot closest to the motherboard. Your millage may vary) and turned the computer on. It took a couple of tries to get the wire taped firmly enough against the contact points, and I suspect you may need to work quickly before it becomes detached. When the laptop boots the indicator leds will blink then it will restart. I let it run a few times until it lets me go into the setup screen (hit f2) - I suspect that it eventually allows me to do this because the wire loses contact with the reset contacts, which is why I say you need to work quickly. I did this on two separate laptops with success. DISCLAIMER: This could potentially wreck your computer. I take no responsibility for anything that goes wrong: you do this at your own risk.
5/12/2016 3:58:31 PM •
Toshiba...
Answered
on May 12, 2016
Toshiba Laptop turns itself back on after being shut down
go to toshiba's website
www.toshiba.com select your proper device and go to support put in your model number there have been some bios updates to resolve this issue. load all bios updates and you should eliminate this known issue.
good luck!
Ruben
7/19/2009 1:33:41 AM •
Toshiba...
Answered
on Jul 19, 2009
Clear presets on fm tuner
On version 1.9 (search google for update if needed) click on Japan radio button. Wait until scan is complete then click on WW again. This cleared the presets on mine.
Hope this helps.
5/9/2009 8:11:34 PM •
Toshiba...
Answered
on May 09, 2009
Japanese Visa Application with COE denied. Why?
How to Get Employment Security With Correct Japan Work Visa Japan is no different from other developing nations whereby grass seems greener on its side of the pasture. It attracts its fair share of foreign businesses as well as nationals seeking to work within its lands. Albeit many adhere to immigration procedures, some choose to test their limits on the basis of ignorance or defiance. By understanding the different types of work visa in Japan, it assures its foreign workers a continual stream of income with no threat of arrest and deportation. Visa simply infers the status of residence. Citizens obviously have no need of it as they automatically satisfy qualifications to freely reside in their country of birth. As for those of alien status who wish to join the local workforce, there should be a category to match one's requirement. Since most countries strive to improve the overall quality of life, professionals are generally welcomed to contribute knowledge and skill. Unskilled labor is normally not granted a visa to avoid flooding and dilution of the workforce. The visa is awarded in accordance to one's area of expertise. Supported with proof of relevant experience, it is based on the field of involvement whilst working in the country. In the event one's work scope changes from one expertise to another, it is essential to apply for a visa under the new circumstances. Different types of work visa in Japan also apply to foreign companies seeking to conduct local business. Domestic companies based abroad wishing to set up a local point of presence need to provide supporting documents to justify internal transfer of foreign workers. Governmental staff for diplomatic duties is assigned a category for legal residence. Over and above the general groupings, designated activities also garner approval from the authorities. Domestic service for non-native residents and citizens of certain nations on working holidays fall into this category of working visa. This, by no means, is the end of the list as it is best to consult the authorities on which visa serves best.Click Here For More Details: http://japanjobandvisaservice.com/blog/change-your-luck-when-apply-work-visa
5/22/2023 2:52:35 PM •
Toshiba...
Answered
on May 22, 2023
How can a fix error code oxcoooooof
Just restore your system from a backup taken before the error code started.
If you have no backup then you need to format your hard disk and do a complete reinstall of all your software.
3/19/2020 10:52:50 AM •
Toshiba...
Answered
on Mar 19, 2020
How to play a DVD on Toshiba Satellite Pro C850
If you know the DVD and the DVD drive is in proper working order, it could mean that the software you are running just may have some problems. Try downloading a copy of VLC (VideoLan Client) this application is free and open source (and no it's not something I created and am just trying to get people to use...it's just something that works great, and completely free) VLC can play almost any video file or DVD that it encounters. If VLC can't play it, I would think it's likely there may be something with your disk or your DVD drive.
3/11/2020 8:58:46 AM •
Toshiba...
Answered
on Mar 11, 2020
My computer does not connect to wifi and only show
Hello,Do you have a wifi card in the computer? It is a hardware part that you need so that the computer can connect to the wifi. If you have that but can't find it in the operating system. I suggest that you either install or update the driver for it. You can use
RadarSync to scan your computer for the available updates of your wifi driver. Make sure that you connect to the internet first using your ethernet so that it will detect the available driver updates somewhere in the databases of the manufacturer. Davidhttp://goo.gl/CxsY9u
9/25/2019 4:52:00 PM •
Toshiba...
Answered
on Sep 25, 2019
