20 Most Recent
Sony VAIO VGN-FW170J/H Laptop Questions & Answers
Sony vaio error 333
Try deleting partition(s) and re-creating. This problem has been around for a while. It could be the hard drive, but most say it's the disc.
9/26/2012 1:30:10 AM •
Sony VAIO...
Answered
on Sep 26, 2012
My icon on my desktop is missing but all can be
Which icon are you missing? If the program shows up when you go through the "Start and All Programs" you should be able to just right click the program that you want on the desktop and select "Send To" and then choose "Desktop (create shortcut)" and your done.
7/2/2010 3:14:03 PM •
Sony VAIO...
Answered
on Jul 02, 2010
Sony VGN-FW170J Not Turning On
If the PSU is good and there is no lights coming on when you either plug in the charger or attempt to turn on the machine then it's simply the motherboard.
There is a good chance that a few transistors blew out. Laptop repair or even motherboard replacement is very expensive. If the computer is still under warranty then take advantage of the product defect and get it repaired or replaced.
6/7/2010 1:59:41 AM •
Sony VAIO...
Answered
on Jun 07, 2010
I have a Sony VGN-FW17)J... It started freezing
Probably has a dead fan inside and this is causing it to overheat. You will have to take it apart and replace the fan. To test if it is heat related spray duster or freeze spray inside it to keep things cool.
5/5/2010 3:56:52 AM •
Sony VAIO...
Answered
on May 05, 2010
Taskbar power management
You need to calibrate your battery. Go to your BIOS then look for battery calibration then RUN the calibration process.
Check if the problem stills occurs.
Thanks. Cheers!
4/21/2010 4:54:51 PM •
Sony VAIO...
Answered
on Apr 21, 2010
Code error 0xc0000185
Do you the Windows user suffer Error Code 0xc0000185 on your PC or laptop.
Well, this is a blue screen of a ***** error note telling me that your boot configuration info is missing (Error Code 0xc0000185)
This BSOD error code issues with a note - The Boot Configuration Data for your PC is missing some required information.
Causes of Error Code 0xc0000185:-
1. Suffer a cable attachment joining to your system and the hard drive.
2. Defective or missing boot files.
3. The disk drive gets damaged.
4. Wrong disk drive.
Solutions of Error Code 0xc0000185:-
1: Do sure that Wire is Correctly Connected [Only for PC]
2: Automated Repair
3: Check Hard Disk for Errors
4: Repair your System to Fix Error 0xc0000185
Full Solution -
9/14/2022 11:53:07 AM •
Sony VAIO...
Answered
on Sep 14, 2022
Lost video on svt131a11l
Try to:Open Computer by clicking the Start button and then clicking Computer.Navigate to the folder or drive that used to contain the video file, right click it and then click Restore previous versions. https://8ballpool.onl/ https://googlehangouts.ooo/ https://omegle.onl/
9/30/2018 12:52:58 AM •
Sony VAIO...
Answered
on Sep 30, 2018
System has slowed down and freezes regularly. it
A lot of anti viruses cant find or get rid of pups, which are potentially unwanted programs that sneak onto your computer, go to mybleepingcomputer.com and download and run adwcleaner, its free and gets the boogy men out.
1/22/2018 2:02:26 AM •
Sony VAIO...
Answered
on Jan 22, 2018
My laptop has limited internet access. I've called
Hello -
Depending upon where (in your home?) you use your Sony Vaio laptop (via WiFi?) you may need a WiFi booster or extender. Or, you may find that moving your WiFi router to another location in your home will improve your connection without diminishing the connections for other laptops used in your home.
Perhaps the information here will prove instructive:
https://www.repeaterstore.com/pages/wifi-booster-repeater-extender-differences
Note: If the router needs to be moved in your home, you will probably need a technician for your Internet provider to come to your home to relocate it and connect it properly.
12/28/2017 11:26:53 PM •
Sony VAIO...
Answered
on Dec 28, 2017
