20 Most Recent HP Hewlett Packard Pavilion DV9000Z 17" NOTEBOOK LAPTOP PC Questions & Answers
Splashtop remote does not work with top down
verify your power options are set to when i close lid 'do nothing' If you need further help, reach me via phone at https://www.6ya.com/expert/joel_63c670a84e9f6a97
12/9/2013 11:58:09 AM • HP Hewlett... • Answered on Dec 09, 2013
2answers
J'ai formater mon pc HP
12/20/2012 8:56:43 AM • HP Hewlett... • Answered on Dec 20, 2012
HP DV9000 blank screen 1 long and 2 short beeps at start up
This is a indicator of motherboard failure, first! remove one stick of ram memory and try again, if no! remove second piece and put back the first and power up, if no result! the motherboard has major issues and will need to be replaced, or new laptop.
4/23/2012 10:58:16 AM • HP Hewlett... • Answered on Apr 23, 2012
2answers
My dv9000 keeps shutting down
probably a bad sector in the hard drive. hat will cause your problem Hard drives are good for a 5 to 10 year average if used everyday. If the computer is switched off without going through the normal proceedures of shutting it down will decrease the life span as well
1/8/2011 2:39:35 AM • HP Hewlett... • Answered on Jan 08, 2011
Pavillion dv9040us plays dvd but not cd.
The drive has a bad audio laser - both the video and the audio lasers use the same lens. You can replace the whole drive for a reasonable cost than having it repaired.
12/17/2010 12:20:47 AM • HP Hewlett... • Answered on Dec 17, 2010
Laptop shuting down and beeping
Forget about calling HP. Unless you recently purchased it, the warranty is already out. There's a known motherboard problem that HP will warranty ONLY if it's a few months old. Check their website or call if you have half a day to waste. Sorry for being negative, but in reality, there's not much hope.
Here's a "fun option" that has worked for some:
1. Power down the laptop.
2. Unplug the AC cord.
3. Remove the battery.
4. Plug the AC cord in again.
5. Push and hold the power on button for 30-40 seconds.
6. IF it boots up, install the battery and you're good to go.
They say this procedure removes static electricity. Actually, it's a sign of the motherboard going out. Days are numbered. Back up all data files when/if you can.
9/11/2010 1:40:21 PM • HP Hewlett... • Answered on Sep 11, 2010
I have a compaq presario c700. notebook. when i
Here is the link to the HP Support Website for your Model.Try Downloading/Installing any/all of the Most Current Updates.
http://h20000.www2.hp.com/bizsupport/TechSupport/ProductList.jsp?lang=en&cc=us&taskId=135&prodTypeId=321957&prodSeriesId=3466274
8/28/2010 5:16:55 AM • HP Hewlett... • Answered on Aug 28, 2010
REMOVING MOTHER BD.
wow. okay. start by removing the battery. then unscrew and remove any faceplates on the bottom of your laptop. i.e. ram hatch, wireless card hatch, harddrive hatch, etc. not all laptops have hatches.keeing the laptop upside down on a flat sturdy surface, begin to remove all screws on the bottom, making sure to organize them and mark down or take notes of where they were in a log. make sure you constantly touch a metal case or large metal object of some sort to discharge any static. once the screws from the bottom are removed, flip the laptop over. open the screen all the way, so its flat or almost flat and pry up the faceplate that is abov the keyboard and below the screen. this face plate has cheep japanese tabs so be sure to remove it carfully but firmly. now you have access to the keyboard screws. remove the keyboard screws, taking note of thier location and remove the keyboard. the keyboard will have a long cable like looking thing attaching it to the motherboard. remove it properly. set the keyboard aside and begin to remove the remaining screws that you can find that attache the plastic case to the motherboard or internal components. note thier locations and organize accordingly. when you get this far comment back and let us know okay?
6/4/2010 7:06:43 PM • HP Hewlett... • Answered on Jun 04, 2010
2answers
Beep Code 1 long and 2 short
the problem is with your RAM & u will have to replace the RAM. this will work
9/18/2009 3:30:28 AM • HP Hewlett... • Answered on Sep 18, 2009
HP Pavillion laptop special edition
Hi...
Reinstall the video driver, that should fix the issue.
Else it seem to be a video card or hareware issue.
Let me know
Thanks
Smith
8/11/2009 5:12:15 AM • HP Hewlett... • Answered on Aug 11, 2009
Some software not run on my 64bit what i need
most software runs 32 bit. so better get 32 bit Operating system installed.
7/7/2009 6:55:33 AM • HP Hewlett... • Answered on Jul 07, 2009
My laptop keyboard is typing different letters and numbers
It sounds like your keyboard is starting to go. Try plugging a usb keyboard and using that. If your keyboard needs replacing, it may be around $50, but that will depend.
3/18/2009 9:19:10 PM • HP Hewlett... • Answered on Mar 18, 2009
DV9000Z beep codes
1 long, 2 short on the HP DV9000 is "bad video adapter". Since your video card is integrated into your motherboard, you're looking at replacing the entire board (between $200-$400 on average) + labor costs. It would be more cost effective to purchase a new laptop for $100-$200 more, with full warranty.
Hope this helps, and remember to rate those that offer free help :)
9/30/2008 2:43:00 AM • HP Hewlett... • Answered on Sep 30, 2008
3answers
I need to know how to turn on a HP X13-04657 LAPTOP, all the lights are on but nothing on the screen.
HP X13-04657, is 2007 PC THOSE this PC has CCFL back lamp strip that is dead.Vista era PC, laptops. are hard to work with now, 17 years old.is this not a HP COMPAQ presario HP X13-04657 (wrong name!) sorry !became HP in 2002. so is HP but manuals are super hard to find now. that x13 is part of the microsoft license code vista. (so is distraction to what it is)the real name of the Laptop is and was Presario CQ61 laptop CQ61 the PC has bottom sticker that shows the real names of PCs.CQ61-219TU is real name of on CQ61, there area many different sub codes, and they are not all the same.CQ61-306AX this had CCFL (cold cathode florecent lamps) that love to fail 3 waysdead, blinks ,dime or yellow = white.was made until 2009 and evolved, to LED backlamps.-410 is CCFLI will answer for CCFL as those just love to fail,but the the test is so easynow the answer for ANY laptop this old. 2007 and older. black screen all the time, and BIOS screens dead, answers only me. here. remove the main battery (large) it simply snaps off the bottom.the power pack is next we run the PC on your power pack AC to DC it must make the screen glow with something, do not use the wrong pack as in mixed up with others.now the lap top seems on, even the fan blows, LED glowpoint a flash lamp at the screen ,dark' room , and of you see any kind of LCD data on the screenthe CCFL lamp below #1 is bad.this is phase 1 testing, as other things can fail too. The keyword below is Mercurythis tells me it is those pesky CCFL glow tubes. 2007 is the year some PC went to LED back lamps. yes I was correct the service manual I did find proves they made both lamp types ccfl-hp07-psnmcz4s4yabbrmds04n13cd-d-0.jpg
4/17/2024 12:37:57 PM • HP Computers &... • Answered on Apr 17, 2024
Dove posso scaricare il driver per HP ScanJet 8270? ente compatibile per windows 10...
Question edited for clarity. Question translated to English. We only speak English on this North American website. https://www.google.com/search?q=hp+scanjet+8270+driver+windows+10
HP Scanjet 8270 Document Flatbed Scanner
Hewlett-Packard https://support.hp.com > ca-en > drivers > hp-scanjet-827... Download the latest drivers, firmware, and software for your HP Scanjet 8270 Document Flatbed Scanner ... drivers free of cost for Windows and Mac ... Windows 10 / ...
Hewlett-Packard https://support.hp.com > ee-en > drivers > hp-scanjet-827... Download the latest drivers, firmware, and software for your HP Scanjet 8270 Document Flatbed Scanner. This is HP's official website to download the correct ...
HP Scanjet 8270 Document Flatbed Scanner drivers - Download
Softonic https://hp-scanjet-8270-document-flatbed-scanner-drivers.en.softonic.com Download the latest and official version of drivers for HP Scanjet 8270 Document Flatbed Scanner. This driver package is available for 32 and 64 bit PCs. It is ...
HP Scanjet 8270 Document Flatbed Scanner drivers - Free ...
Download.it https://hp-scanjet-8270-document-flatbed-scanner-drivers.en.download.it Download HP Scanjet 8270 Document Flatbed Scanner drivers varies-with-device. Software drivers for the 8270 flatbed model of the HP Scanjet printer. ..
4/10/2024 8:38:39 PM • HP Computers &... • Answered on Apr 10, 2024
2answers
HP 8440P Laptop. I don't remember my password. Help needed for HP 8440p.
This video shows you what to do if you forget your computer password:
4/6/2024 8:00:24 AM • HP Computers &... • Answered on Apr 06, 2024
2answers
How to do a bios recovery on a hp pavilion dv5-1004nr
This video shows you how to restore the BIOS in your computer:
4/6/2024 7:57:59 AM • HP Computers &... • Answered on Apr 06, 2024
Hp dv8 not charging battery
You can follow the steps in this video to troubleshoot your battery:
4/6/2024 7:13:37 AM • HP Computers &... • Answered on Apr 06, 2024
Hp supply central pin connected to the 19V power
  1. Central Pin: In many laptop power supply connectors, especially those using the barrel-type connector, there's a central pin that carries the voltage (typically around 19 volts for most laptops) to power the device.
  2. Voltage and Polarity: It's crucial to ensure that the voltage supplied by the power adapter matches the requirements of your laptop. Most laptops operate on 19 volts, but there are exceptions, so always double-check the specifications of your laptop and the power supply.
  3. Polarity: Additionally, the polarity of the connector is important. The central pin typically carries positive voltage, while the outer sleeve of the connector is the ground (negative). Reversing polarity can damage your laptop, so make sure the connector is inserted correctly.
  4. Safety: Always use the power adapter that came with your laptop or a compatible replacement from a reputable manufacturer. Using an incorrect or incompatible power adapter can not only damage your laptop but also pose safety hazards such as overheating or electrical fires.
  5. Replacement: If you need to replace your laptop's power adapter, ensure that the new adapter provides the correct voltage, polarity, and wattage for your laptop model. It's often safer to purchase adapters from the laptop manufacturer or certified third-party suppliers to guarantee compatibility and safety.
3/30/2024 8:53:24 PM • HP Computers &... • Answered on Mar 30, 2024
3answers
I got a 4 year HP laptop and it show a black screen and if I press Esc it will say Esc..start up and will do the same F2 and others.
If your laptop starts but the screen remains black, this video shows you the troubleshooting steps to follow:
3/27/2024 7:16:54 AM • HP Computers &... • Answered on Mar 27, 2024
HP Hewlett Packard Pavilion DV9000Z 17" NOTEBOOK LAPTOP PC  Logo
16 questions posted
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • HP Computers & Internet
Most Popular Question
laptop keyboard typing different letters
  • Computers & Internet
