20 Most Recent
Toshiba Satellite A215-S6820 Notebook Questions & Answers
Need to replace dvd dr and can't get notebook apart.
You need to have a manual of that on how to remove. It is hard for the people who do not have experience in laptop trouble but you can do it with your self. You need to follow of this some instruction.
The first things you should do is to remove the battery.
Insert a sharp thin object between the keyboard securing strip and the laptop base and carefully lift up the strip.
After that you can continue removing the keyboard strip with your fingers.
Remove the keyboard securing strip.
Remove two screws securing the laptop keyboard.
After you remove
the screws, lift up the keyboard and place is so you can access the
keyboard connector on the system board.
If you need to remove and replace the keyboard, you can do it now.
Before you pull the keyboard cable from the connector you have to open
the connector.
To remove the DVD/CD-ROM drive, remove the securing
screw first. After that push on the drive to slide it away from the
laptop base.
Grasp the drive and remove it from the laptop.
Before you replace the optical drive, do not forget to transfer braces to a new optical drive.
You can view some photos of that procedure here,
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-5205/remove-laptop-dvd-cd-drive.htm
10/7/2009 6:45:57 AM •
Toshiba...
Answered
on Oct 07, 2009
Japanese Visa Application with COE denied. Why?
How to Get Employment Security With Correct Japan Work Visa Japan is no different from other developing nations whereby grass seems greener on its side of the pasture. It attracts its fair share of foreign businesses as well as nationals seeking to work within its lands. Albeit many adhere to immigration procedures, some choose to test their limits on the basis of ignorance or defiance. By understanding the different types of work visa in Japan, it assures its foreign workers a continual stream of income with no threat of arrest and deportation. Visa simply infers the status of residence. Citizens obviously have no need of it as they automatically satisfy qualifications to freely reside in their country of birth. As for those of alien status who wish to join the local workforce, there should be a category to match one's requirement. Since most countries strive to improve the overall quality of life, professionals are generally welcomed to contribute knowledge and skill. Unskilled labor is normally not granted a visa to avoid flooding and dilution of the workforce. The visa is awarded in accordance to one's area of expertise. Supported with proof of relevant experience, it is based on the field of involvement whilst working in the country. In the event one's work scope changes from one expertise to another, it is essential to apply for a visa under the new circumstances. Different types of work visa in Japan also apply to foreign companies seeking to conduct local business. Domestic companies based abroad wishing to set up a local point of presence need to provide supporting documents to justify internal transfer of foreign workers. Governmental staff for diplomatic duties is assigned a category for legal residence. Over and above the general groupings, designated activities also garner approval from the authorities. Domestic service for non-native residents and citizens of certain nations on working holidays fall into this category of working visa. This, by no means, is the end of the list as it is best to consult the authorities on which visa serves best.Click Here For More Details: http://japanjobandvisaservice.com/blog/change-your-luck-when-apply-work-visa
5/22/2023 2:52:35 PM •
Toshiba...
Answered
on May 22, 2023
How can a fix error code oxcoooooof
Just restore your system from a backup taken before the error code started.
If you have no backup then you need to format your hard disk and do a complete reinstall of all your software.
3/19/2020 10:52:50 AM •
Toshiba...
Answered
on Mar 19, 2020
How to play a DVD on Toshiba Satellite Pro C850
If you know the DVD and the DVD drive is in proper working order, it could mean that the software you are running just may have some problems. Try downloading a copy of VLC (VideoLan Client) this application is free and open source (and no it's not something I created and am just trying to get people to use...it's just something that works great, and completely free) VLC can play almost any video file or DVD that it encounters. If VLC can't play it, I would think it's likely there may be something with your disk or your DVD drive.
3/11/2020 8:58:46 AM •
Toshiba...
Answered
on Mar 11, 2020
My computer does not connect to wifi and only show
Hello,Do you have a wifi card in the computer? It is a hardware part that you need so that the computer can connect to the wifi. If you have that but can't find it in the operating system. I suggest that you either install or update the driver for it. You can use
RadarSync to scan your computer for the available updates of your wifi driver. Make sure that you connect to the internet first using your ethernet so that it will detect the available driver updates somewhere in the databases of the manufacturer. Davidhttp://goo.gl/CxsY9u
9/25/2019 4:52:00 PM •
Toshiba...
Answered
on Sep 25, 2019
