20 Most Recent
Sony VAIO VGN-CR420E/T Laptop Questions & Answers
The screen of my Vaio flickers when the charger is
TRY SWITCHING OFF YOUR COMPUTER MONITOR( REMOVE THE POWERCODE). IS THE PRON SOLVER. IF YES PROB WITH MONITOR POWER SECTION. IF NO REMOVE POWER OF COMPUTER CPU. AND ON THA UPS . IF IT IS STILL FLICKRING PROBE WITH UPS. ELSE RE[PLACE SMPS OF COMPUTER
2/7/2011 4:31:08 PM •
Sony VAIO...
Answered
on Feb 07, 2011
I dont know how to
Start the computer, tap F2 key. If not entering the BIOS, restart the computer press and hold the F2 key.
Thanks,
12/15/2010 1:01:45 AM •
Sony VAIO...
Answered
on Dec 15, 2010
HOW DO I REINSTALL MY OPERATING SYSTEM ON IT. IT
im not sure what laptop you have
but when you first boot up in the bio
press control and one of the f keys at the same time
usually f10 or f11, go to your websight to be sure
dell.com gateway.com toshiba etc. under support
look for recovery options
7/21/2009 8:06:08 PM •
Sony VAIO...
Answered
on Jul 21, 2009
I have loaded Win XP
It is likely that the keyboard at the very least is defective and causing you an issue. Keyboards are very cheap to replace and a new one can be found on ebay or through a local sony store or good computer store. Not too difficult to remove and replace. If the replacement does the same thing then the keyboard/mouse controller on the motherboard is defective and the motherboard will need to be repaired or replaced
7/17/2009 8:24:06 AM •
Sony VAIO...
Answered
on Jul 17, 2009
Touchpad and buttons won't click on Sony Vaio
it could be caused because of hardware failure or software failure, in case of hard ware failure it would be best to call sony tech support but in case of software issue , if you remember the day it was working fine,
do a system restore to the date it was working fine, which will reset your software configuration to the date you know it was working ok, so if it was caused by software issue it will be resolved, but any programs that you installed after the restore date will be lost
to do system restore
reboot your system when you see the sony logo start tapping the F8 key and you will come to a menu here select safe mode and boot and then
Click Start, point to All Programs, point to Accessories, point to System Tools, and then click System Restore. System Restore starts select the bold date your system was working fine and continue as it guides,
If you think the information i gave you was helpfull please do rate me
Regards
Ltoso
7/9/2009 7:24:00 AM •
Sony VAIO...
Answered
on Jul 09, 2009
Code error 0xc0000185
Do you the Windows user suffer Error Code 0xc0000185 on your PC or laptop.
Well, this is a blue screen of a ***** error note telling me that your boot configuration info is missing (Error Code 0xc0000185)
This BSOD error code issues with a note - The Boot Configuration Data for your PC is missing some required information.
Causes of Error Code 0xc0000185:-
1. Suffer a cable attachment joining to your system and the hard drive.
2. Defective or missing boot files.
3. The disk drive gets damaged.
4. Wrong disk drive.
Solutions of Error Code 0xc0000185:-
1: Do sure that Wire is Correctly Connected [Only for PC]
2: Automated Repair
3: Check Hard Disk for Errors
4: Repair your System to Fix Error 0xc0000185
Full Solution -
9/14/2022 11:53:07 AM •
Sony VAIO...
Answered
on Sep 14, 2022
Lost video on svt131a11l
Try to:Open Computer by clicking the Start button and then clicking Computer.Navigate to the folder or drive that used to contain the video file, right click it and then click Restore previous versions. https://8ballpool.onl/ https://googlehangouts.ooo/ https://omegle.onl/
9/30/2018 12:52:58 AM •
Sony VAIO...
Answered
on Sep 30, 2018
