20 Most Recent IBM Lenovo ThinkPad T61 Notebook Questions & Answers
I cant seem to download anything? It shows up only in the dowload file but just as a word file
Hi this Alex Walker I am Expert to help you for this Issue Call Me +1(404)981-1535. I will be glad to assist you
11/18/2015 8:39:15 PM • IBM Lenovo... • Answered on Nov 18, 2015
How do i clean the fan on my lenovo thinkpad?
I would take the screws off of the bottom first. Be careful not to miss any screws, as there may be some under the padding. Remove the bottom cover, and boom. There's the fan waiting to be cleaned. I suggest using a bottle of compressed air.
6/3/2014 1:56:51 PM • IBM Lenovo... • Answered on Jun 03, 2014
Lenovo t510 white screen on power up
if you have access to an external screen, attach it via the VGA port and restart the PC, if it comes up then you have a faulty inverter. Carry the machine to a recognized tech to replace inverter. Worse case scenario, you may have a faulty board.
11/15/2013 2:19:09 PM • IBM Lenovo... • Answered on Nov 15, 2013
3answers
ERROR 0210: Stuck key 7B Press
There are issues with the ThinkVantage Button at boot as it doesn't do what its suppose to. Just use the F1(BIOS Setup), F11(pre-boot/recovery area) and F12(boot device selection).
Just a reminder to practice press and release when pressing a button. We sometimes get impatient and do a key hold down for a while rather than multiple press and release.
I hope this would resolves your ERROR 0210: Stuck key
4/27/2013 4:42:50 AM • IBM Lenovo... • Answered on Apr 27, 2013
My lenovo t61 screen is cloudy white
definitely hardware sounds like yo have a disconnected LCD cable or most likely its a bad lcd screen
4/21/2013 4:35:25 AM • IBM Lenovo... • Answered on Apr 21, 2013
LCD backlight replacement
If the LCD screen on your IBM laptop is going dim, chances are the backlight is breaking down. The good news is that if you don't want to spend the money to have a technician replace it, you can do it yourself. There's no need to open up the main body of the computer, but you will have to get into the screen to do the work. Here's how. Power off your IBM and remove the battery. Remove the nine screws (three on each side) on the side of the screen. Once the screws are removed, the plastic bezel (screen guard) can be removed. Pop the bezel out, exposing all of the LCD screen. Pull the LCD screen gently away from the computer by the corner. Be mindful that the screen is still connected to the computer by a ribbon cable. Remove the tape over the ribbon cable where it connects to the screen and gently pull the cable to disconnect it. Turn the LCD facedown, and remove the piece of tape that holds the top metallic foil against the back of the LCD. Lift the metallic foil to expose the backlight. Remove the single screw at the end of it that holds it in place. Unclip the wire at the end of the backlight from the inverter (power source to the backlight), and remove it from the LCD. Replace it with the new backlight (available at any electronics store or online). Be sure the new backlight is compatible with your particular IBM model. Reassemble the computer reversing the order in which you took it apart. Remontage / reassembly Lenovo Thinkpad T60 ou T61 all versions http://www.youtube.com/watch?v=dxNB3sxUfos ThinkPad Back Light Replacement http://www.youtube.com/watch?v=tr_trXGEYT4 IBM lenovo T61 display problem http://www.youtube.com/watch?v=Em6XBA_nOZ4
2/5/2013 9:18:30 PM • IBM Lenovo... • Answered on Feb 05, 2013
2answers
My sistem is so slow?
What is it you cant use the internet or is your computer slow ?the problem could be 2 in the same You might have a virus or malware ?
Press windows button and in the search type msconfig go to startup tab and uncheck those you dont want to start.
scroll to the bottom toolbar bottom of screen right click you can select task manager applications also processes you will see whats running on your computer and ticking over you might have a virus
http://www.majorgeeks.com/Microsoft_Security_Essentials_for_Windows_d6242.html
microsoft security essentials your operating system must be registered
Win7/Vista/XP 64 bit
http://majorgeeks.com/downloadget.php?id=4281&file=1&evp=dbb3b0aebe6a6a4ff18089a6489a5e62 anti malware free edition Win XP/2003/Vista/Windows7
if you see something running that you does not need to be running select end now then you might you might uninstall that particular program
and some unnecessary programs
you should also check leads from motherboard to hard drive for secure dust free connections
click start control panel administrative tools computer management disk management right click on your drive select properties click tools you should see click check now
click start tick in both boxes this will schedule to on restart
do not have any input while chkdsk utility is in progress any might damage your computer
also you might download and use this registry cleaner it is totally free to use
http://download.cnet.com/ccleaner/
then defragment your hard drive
adding more ram is the best way of speeding up a computer
If youre not sure if a module is right for your system use the
Crucial Memory Advisor tool for a list of guaranteed compatible modules
you should always ask for a guarantee on compatibility before purchasing any ram and buy working pairs if possible
you might have to many programs running at the same time putting to much strain on the CPU central processing unit
try uninstalling a few unnecessary programs
This tool deletes unnecessary or temporary files on your hard disk so you can increase the amount of storage space you have.
Delete the files using Disk Cleanup
If you want to reduce the number of unnecessary files on your hard disk to free up disk space and help your computer run faster, use Disk Cleanup.
It removes temporary files, empties the Recycle Bin, and removes a variety of system files and other items that you no longer need.
Open Disk Cleanup by clicking start all programs accessories system tools and then clicking Disk Cleanup.
In the Disk Cleanup Options dialog box, choose whether you want to clean up your own files only or all of the files on the computer.
If you are prompted for an administrator password or confirmation, type the password or provide confirmation.
If the Disk Cleanup Drive Selection dialog box appears, select the hard disk drive that you want to clean up, and then click OK.
Click the Disk Cleanup tab, and then select the check boxes for the files you want to delete.
When you finish selecting the files you want to delete, click OK, and then click Delete files to confirm the operation.
Disk Cleanup proceeds to remove all unnecessary files from your computer.
Watch the demo (1:00)
this should speed up your computer
Hope this helps.
12/5/2012 11:13:35 AM • IBM Lenovo... • Answered on Dec 05, 2012
How can i change my password
You can remove or change the Window's User or administrator's password. You need access to a computer with Internet access to download the Hiren's Boot CD and burn it onto a CD. Then insert this CD into the laptop/computer and boot up the laptop/computer with the Hiren's CD and follow the instructions. There are very useful utilities CD and it a Linux boot CD which contains quite a lot of Utility programs including a password removal program. Click on one of these links to download HIREN'S BOOTCD :- http://www.hirensbootcd.net/ http://67.20.82.163/
12/4/2012 8:33:58 AM • IBM Lenovo... • Answered on Dec 04, 2012
0answers
How do i get internet access for lycamobile on my laptop
You don't. Lycamobile sim cards are for cell phones to make calls. It's basically a calling card.
10/13/2012 4:27:01 PM • IBM Lenovo... • Answered on Oct 13, 2012
Cannot boot from any device screen is showing
Remove hard drive and re-seat. If there is still a problem take these further steps.Press F key (correct F key is displayed on screen) during boot. Enter BIOS and make sure hard drive is still logically attached.Check boot order. Hard drive should be 1st for faster boot.
10/1/2012 9:02:13 PM • IBM Lenovo... • Answered on Oct 01, 2012
T61 won't go past the Microsoft loading screen
Press F8 during boot, and load Safe Mode. A program may be preventing a proper startup.Try disabling startup programs. Go to Start > Run (search in Win 7) and type MSConfig > Startup tab and uncheck anything that you don't want Windows to load automatically. It will make Windows boot faster and use less resources while running. This just disables them in startup. Programs will still load, but when you initiate.
10/1/2012 8:53:27 PM • IBM Lenovo... • Answered on Oct 01, 2012
0answers
2answers
I HAVE BAIOUS PASSWOR PROBLEM I WANT TO REMOVE THE PASS WORD
The password to change the settings in the BIOS is not stored in the CMOS (battery backed RAM). It is in an EEPROM which retains its data without power. Unfortunately there is no way to reset this data. Lenovo's service manual requires the motherboard to be replaced. There is some information on various forums on the web suggesting that if you have some eltronics knowledge and an EEPROM reader, then you can solder some wires on to the EEPROM and read the data. This is not a simplew process, however. I would try to see if you can buy a second-hand T61 to swap the motherboard out.
9/14/2012 9:45:54 PM • IBM Lenovo... • Answered on Sep 14, 2012
Windows will not start, blue screen comes up saying unmountable_boot_volume
You probably have some viruses and malware.Start your PC and press F8 several times until the boot menu comes up. Then select "Safe Mode with Networking". Now get some or ALL of the FREE programs below.Download, Install and Run Malwarebytes Anti-Malware:http://majorgeeks.com/download.php?det=5756When Installing choose the non-pro version.Download, Unzip, Install and Run TDSSKiller:http://majorgeeks.com/Kaspersky_TDSSKiller_d6895.htmlDownload, Install and Run Super Anti-Spyware:http://majorgeeks.com/SUPERAntiSpyware_d5116.htmlIf you have an outdated Anti-virus program then Download, Install and Run Avira Anti-Virus:http://majorgeeks.com/Avira_AntiVir_Personal_-_FREE_Antivirus_d955.htmlMake sure to select ALL of the "threat categories" when you install or configure Avira...You should be in pretty good shape if you run and install all of these programs.
8/21/2012 5:49:22 PM • IBM Lenovo... • Answered on Aug 21, 2012
IBM Lenovo ThinkPad T61 Notebook Logo
85 questions posted
Top IBM Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
ExpressFiX
ExpressFiX
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
ThinkPad IBM
  • ThinkPad IBM
Most Popular Question
clean fan lenovo thinkpad
  • Computers & Internet
