20 Most Recent
Compaq Hewlett Packard nc6220 PC Notebook Questions & Answers
I have a problem that happens after going on line
Hi , I think your updates download has interfered with DVD driver that was installed in that machine ,I want you to try this look for installation drivers for the DVD/CD ROM and install it . The DVD/CD should work now .
Disk read error
Step 1: Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer You could select the option start at last known configuration that worked this will tell you if and what file has been corrupted or missing then you will know if its a hardware issue You might use the system restore to restore your system to an earlier time click start all programs If it is a hardware issue the system restore might not work Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer. Use the system restore to restore your system to an earlier time click start all programs accessories system tools you should see your system restore option if it is a hardware issue the system restore might not work Manual restore points that you specify with the System. Configuration utility Installation restore points that occur before you install a program or a service you can use the system checkpoints or the installation restore points to restore your computer's settings to a date when it operated correctly. This may also help determine the cause of the configuration error. To perform a system restore, follow these steps: 1.Click Start, click Run, type msconfig, and then click OK. 2.On the General tab, click Launch System Restore. 3.Select Restore my computer to an earlier time, and then click Next. 4.Calendar dates in bold are possible restore points. Click the most recent one to view system restore information. 5.Select a system checkpoint or an installation restore point, and then click Next. 6.Close all other programs. 7.To start the system restore, click Next. 8.Your computer restarts. Repeat steps 1 through 8 until you fix your configuration issue.
Out of frequency range set lower resolution
reboot the system by pressing F8 if your using windows OS and select last good configuration.
you can try also selecting Enable VGA mode (press F8 while rebooting and select ENABLE VGA mode).
hope this helps, please rate.
I want to install xp on compaq nx 6310 give the procedure with pendrive
2006 PC (HP.coM) 16 years old.. ouch.
XP (microsoft) is now a horrible virus magnet, and there is ZERO support now, are you using the last XP earth 2020???
gee google that. 2001 to 2007 was XP rein , vista 2007
I bet there are 1millons of web site still with XP usage .(old topics)
google them. but Microsoft purged theirs.
it is not sold at all, so how in the world can you get the installer on any pen drive, and XP installed from CD not pen..
worst of all XP installer, can not us 99% of all USB ports and then only half after the install (unless you force them via F6 and floppy drive with xp drivers on the floppy for THIS PC)
to use any relic PCs run LINUX> not XP
