20 Most Recent
Jobo Giga One ULTRA MP3 Player Questions & Answers
Vocalizer 3 output checked cables and swapped out. 1300 watt power adaptor lights up. sound indicator light is on but no sound. tried mono and stereo. power adaptor problem?
If you've checked the cables, swapped them out, and ensured that the power adapter is providing power to the Vocalizer 3, but you're still not getting any sound output, there are a few additional troubleshooting steps you can try:
1. **Check Volume Levels**: Ensure that the volume levels on the Vocalizer 3 and any connected devices (such as mixers, amplifiers, or speakers) are turned up and not muted.
2. **Test with Different Inputs/Outputs**: Try connecting the Vocalizer 3 to different inputs on your mixer, amplifier, or speakers, and test with different output devices if possible. This can help determine if the issue is specific to certain connections or devices.
3. **Inspect Settings**: Check the settings on the Vocalizer 3 to ensure that the correct input and output sources are selected. Make sure that any settings related to mono/stereo output are configured correctly.
4. **Test with Different Power Adapter**: If you have access to another power adapter with similar specifications, try using it to power the Vocalizer 3. This can help determine if the issue is related to the power adapter.
5. **Reset the Vocalizer 3**: Some electronic devices can benefit from a reset to their factory settings. Refer to the user manual for instructions on how to perform a reset on the Vocalizer 3, and try resetting it to see if it resolves the issue.
6. **Contact Technical Support**: If you've tried the above steps and are still experiencing issues with the Vocalizer 3, it's possible that there may be a hardware problem or malfunction. Contact the manufacturer's technical support for further assistance and troubleshooting guidance. They may be able to provide additional insights or recommend repairs if necessary.
By following these troubleshooting steps, you should be able to diagnose and resolve the issue with the lack of sound output from your Vocalizer 3.
How do I change to degree mode on my porpo YH-2000
- Power Off: Turn off the device.
- Jumper Configuration: Locate the jumper labeled "S16" on the device. Initially, it should be connected to pins 2 and 3.
- Power On (Alarm+All LEDs Flashing): Turn the device back on. You'll see the alarm LED and all other LEDs flashing.
- Power Off Again: Turn off the device once more.
- Jumper Adjustment: Change the jumper configuration from pins 2 and 3 to pins 1 and 2.
- Finished: Your Porpo YH-2000 is now set to the desired angular unit mode.
If you encounter any issues, you can press the reset switch on the back of the device to reinitialize it.
Openfit Shokz battery replacement?
Question edited for clarity, typo and CAPS.
Question moved from Cars and Trucks category.
Claim on the warranty irrespective of how long you have had them. They charge $180 but they cost them $20 to buy from China. Package them up and send them tracked and ask them to replace the batteries.
How long is the warranty on AfterShokz?
While we hope you never need it, all new Shokz purchased from authorized retailers come with a two-year warranty that begins on your date of purchase.
Jan 11, 2019
https://www.google.com/search?q=Openfit+Shokz+battery+replacement
My roadking rk4000 wont charge. I turn it off to charge it but there is no indicator light at all, any suggestions?
Are you using the charging cables that came with it? That is a type C. Are you securely attaching the charging cable? A loose connection would keep the battery from charging. If you had a low battery, you would see a red light. That you have no light at all suggests there is no charge left in the battery. I'm not sure the reset will work with no charge which is why you ought to check the cables first.
But turn it off and then hold down the Multifunction button for 10 seconds to reset it. Then turn it back on and see what happens. If you can, test the charging cable on aother device. If you have another type C charging cable, try it, just to eliminate a bad cable. If these suggestions don't work, you may try the manufacturer's customer support.
Can f2100 remote work on my dishtv box?
The F2100 remote is not explicitly listed as compatible with the AerialBox T2100, I recommend using the remote that came with your AerialBox T2100 for optimal functionality. If you have any specific compatibility concerns, I suggest reaching out to Dish TV customer support for further assistance.
Audiosonic CR-06PL not changing time when following manual instructions.
Set Time Hours and Minutes: Press Time/12/24 and Alarm1/ON/OFF buttons at the same time for two seconds and it will start to blink the hour.
Press and hold the button for a fast setting or tap it briefly to increase the setting by one hour. Now set the minutes with time (press and hold) and min.
How do I set the Audiosonic clock? Set current time Press and hold the time button and simultaneously press the hour to set the hours in 24-hour mode .
