20 Most Recent
Compaq Hewlett Packard Presario SR5110NX PC Desktop Questions & Answers
Case fan not working sr5110nx
Some fans will not engage if the case is open, others need to be activated in bios (set temp). Also check if the wires are reversed. Some have a diode that only works with current in one direction. Very few use an ac current.
Lightscribe
Hello Friend,Some PC also noise like, SMPS fan, CPU fan, external cabinet connect fan. If this types of noise create then you clean all fan dust i think problem solved. You know CUP also create noise it`s default so not any solution.
Proper Procedure for Putting Computer to Sleep
Change your sleep settings in the Control Panel under Power Options. You can set it to never go to sleep or have it to go to sleep after 2 hours. There will be settings to control when the monitor shuts off, when the hard drive shuts off, etc.
Windows open so slowly and
clear all 3rd party startup items you dont need with msconfig.exe. Uninstall bellaliant and use microsoft security essentials as main antivirus software and defragment your hard drive.
Main OS does not mount
Boot in safe modeStart msconfig.exe and configure windows to start with a clean boot.a. Log on to the computer by using an account that has administrator rights. b. Click Start, type msconfig.exe in the Start Search box, and then press ENTER to start the System Configuration Utility.If you are prompted for an administrator password or for confirmation, type your password, or click Continue. c. On the General tab, click Selective Startup, and then click to clear the Load startup items check box. (The Use Original Boot.ini check box is unavailable.) d. On the Services tab, click to select the Hide all Microsoft services check box, and then click Disable all.Note Following this step lets Microsoft services continue to run. These services include Networking, Plug and Play, Event Logging, Error Reporting, and other services. If you disable these services, you may permanently delete all restore points. Do not do this if you want to use the System Restore utility together with existing restore points. e. Click OK, and then click Restart.Boot the machine in normal mode.
The CD drive is jammed,
It has to have the pin hole safety. It is required by IEEE standards. make sure you check the entire face of the CD drive for it. It can be mistaken for light or appear along the tray's edge (making it really hard to see), but I promise it has to be there.
How do I replace a power supply on a Compaq
you can purchase a power supply from any computer store *********** board supports both standard IDE and Serial ATA connections, so you want a power supply that does SATA power as well. Unplug the power cord from the back of the computer. remove the cover from the case and verify that there is no green LED on the board that is lit up (if there is, there is still power on the board). unplug all connections from the current power supply, including all drive power and the large 24pin plug (actually a 4 pin plug that is combined with a 20 pin plug) on the board, then unplug the 4 pin plug near the processor. careful that the 24 pin plug and the additional 4 pin plug near the processor have latches on the side. Remove the 4 screws that hold the power supply in and remove the power supply, install new supply and reinstall the 4 screws. first plug in the 4 pin plug that connects with the 20 pin, the 4 pin plug has no latch, it is held in place by the 20 pin plug. then plug in the 20 pin plug and the 4 pin next to the processor. then plug in the drive power to all of the drives. Install the power plug at the back of the system and you should see a green LED on the board when you insert the power. replace the cover and power the system up.
Need owner manual to burn DVD
just download imgburn which is a free software to burn dvd's etc. Google "imgburn" and follow the appropriate links to download. Its easy to use by the way.
Out of frequency range set lower resolution
reboot the system by pressing F8 if your using windows OS and select last good configuration.
you can try also selecting Enable VGA mode (press F8 while rebooting and select ENABLE VGA mode).
hope this helps, please rate.
