20 Most Recent HP Hewlett Packard Photosmart 425 Photo Studio Digital Camera Questions & Answers
3answers
I lost my phothos at
there is no way to recover the photos which are lost.but dont worry there are two software from which you can recover any type of lost picture very easily.and both the software supports your camera.
also there is contact customer support mentioned in the software home page you can contact them directly if you have any problem in the procedure of recovering photos
check out both the links 1 by 1 both are useful and helpful
just click the link directly
http://www.hetmanrecovery.com/digital_photo_recovery/digital_camera_recovery.htm
just click this link directly to check out second recovery software
http://www.magicuneraser.com/photo_recovery/supported_cameras.php#HP
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya.
3/19/2019 11:07:57 AM • HP Hewlett... • Answered on Mar 19, 2019
Hello. I have a Hp 425 Photosmart digital camera
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
12/20/2009 11:54:19 PM • HP Hewlett... • Answered on Dec 20, 2009
Help with memory card saying unable to format
Hi Eric :)
Please try formatting the Memory card using your computer first in the following manner:
>> Insert the memory card into memory card slot / memory card reader
>> Check the drive letter that it has been assigned by the computer
>> Right click on the drive and select Format option
>> Now this is very important.. Select FAT file system from the drop down options (DO NOT select FAT32).
>> Now Format the card and then try formatting the same card in Camera.
Let me know if that works for you.
Regards,
Srinivas
4/3/2009 9:33:50 AM • HP Hewlett... • Answered on Apr 03, 2009
2answers
I have an HP photosmart 435 that is missing its battery cover, it doesnt work without it is there something i can do to make a replacement?
No easy way to fix as it has contacts in the cover lid and it hinges. Contact a local HP Service Centre. 3D Print possibly, but you need one to scan, unless you can find a good 3D designer. https://www.google.com/search?q=HP+photosmart+435%2C+replacement+battery+cover ..
6/22/2022 10:18:35 PM • HP Cameras • Answered on Jun 22, 2022
HOW TO FIX CAMERA HP 437-033 LENS ERROR/
Please do not shout. The camera will need servicing by a qualified artificer, as the lens gearing requires adjustment.
7/15/2019 8:30:30 AM • HP Cameras • Answered on Jul 15, 2019
My HP model # 500-424 my movies and videos are super zoomed in and I can't fix it. I have windows 10.
try using a differnt video player, the one you are using has been modified to zoom using it's internal controls, if you can find those you can change the settings to view them the way you want. otherwise. again, try a differnt viewer for movies.
11/27/2018 5:14:43 AM • HP Cameras • Answered on Nov 27, 2018
Hp photosmart 435 camera says sd card is locked when not locked
The first thing to check is the SD card to make sure that the lock latch tab is not missing. The second thing is the lock latch sensor in the camera. IF you remove the SD card a lot, the sensor can break or bend and it could be lost in the camera or have fallen out.
4/2/2018 6:08:32 PM • HP Cameras • Answered on Apr 02, 2018
2answers
What is the maximum size SD card for HP pb360t
This information should be in the manual
11/28/2017 8:22:05 PM • HP Cameras • Answered on Nov 28, 2017
0answers
My hp photosmart c200 camera flashes red/green light when depressing shutter button.
Some Cameras flash Red or Green (ie) Red Over Exposed. Green Exposure Set OK. Check Camera Manual to see if you have information on this..
11/6/2017 8:01:42 PM • HP Cameras • Answered on Nov 06, 2017
Hi, I have a problem with my frame and I need to
Try using Google.
9/18/2017 3:30:12 PM • HP Cameras • Answered on Sep 18, 2017
About six months ago I
Please contact HP support staff.
8/14/2017 9:46:30 PM • HP Cameras • Answered on Aug 14, 2017
HP Hewlett Packard Photosmart 425 Photo Studio Digital Camera Logo
4 questions posted
Top HP Cameras Experts
 Mikey
Mikey
ADMIN Eric
ADMIN Eric
Are you a HP Camera Expert? Answer questions, earn points and help others
View Most Popular
HP Cameras
  • HP Cameras
Most Popular Question
lost phothos
  • Cameras
