20 Most Recent
Nokia 3350 Cellular Phone Questions & Answers
Smiley nokia 3350
if you want some reference you can go to YMand look for the symbol combination ofthe emoticons there. that is also the symbols for smileys. like :) ;) T_T ^_^ etc
How to turn off Nokia
The on/off/profile button is a stiff black button located on the top of the phone. Press and hold it for 3 seconds and your phone will switch off.
If its not turning off by the above method, remove the batteries and again place them back. It'll switch off the phone.
Hope this helped. Thanks for using Fixya
Please vote this answer.
Security code is forgotten how to change it
To get security code please contact your service provider.they will provide you the default security code so that you can open your phone.
While you get the security code ,the service provider customer care officer will ask for your personal details to check whether the mobile belongs to you only.If they are satisfied with your answers they will provide with the security code.
thanx
When i type my security
hi, if the phone is asking for the security code when you switch it on but its not accepting the code you have then all you need to do is give me the imei number off the back of the phone under the battery and i can then give you the phones master code which will give you access to the phone and it will also remove the security code and reset it to what it was when new usually 1234, plz dont enter the wrong code more than 5 times as this will lock the phone and it will be impossible to unlock
let me know then i can assist you further ok
No signal nokia 3350
first go to phone setting then go network option. select manual then you will see searching network. if found then select your home operator. but if not work then i suspect your antana switch or PF has troubled. then please repair or change that. it become ok. if not become ok then the way is reinstall your phone application. thanks.
Sir,, i forgot the security code of my cellfone,,
well, sometimes this could be really annoying, have you tried phoning your service provider and asking them to reset your security code. but in some cases you may need to replace the handset.
hope this helps
10/18/2009 12:52:44 AM •
Nokia 3350...
Answered
on Oct 18, 2009
