20 Most Recent
Nokia 6263 Cellular Phone Questions & Answers
How to deactivate fixed dialling
Hi
Fixed dialing is a network-based service which should not be active
unless you specifically ask them for it, perhaps it has been activated
on your account by mistake and another customer is wondering why it
doesn't work for him.
You would have to get in touch with your network
operator to deal with this.
However, it may be possible to activate/deactivate
it through the phone if your network supports this option. But requires
a Pin2 code that can ONLY be provided by your network
You
can go to Contacts > Options > SIM Numbers > Fixed Dial
Contacts > Options > deactivate fixed dialling > Enter Pin 2
code.
Otherwise, put your SIM card in another phone if
possible to see if you get the fixed dial issue still. If yes, please
contact your network for assistance.
Good luck.
Restriction code selecting
HI you can purchase restriction code for your Nokia 6263 mobile from sites like
ProUnlocking.com they are providing unlock code for all mobile models at reliable cost .You first check that whether the code is available for your country and network provider .If yes then pay for it and unlock your phone .
Restriction code
You can get the restriction code for your Nokia 6263 phone from
SuperUnlockCodes.com here you need to specify your country,Network name to which it is locked,IMEI number of your phone.Then they deliver unlock code to you through mail with unlocking instructions.By using this you can unlock your phone easily.
Forgot security code to my nokia 6263
Dear:ur defalt phones codes is 12345 or 00000 u can use it Default 4 Digit user code: 1234 or 0000Default 6 Digit Security code: 123456 or 000000Type *#06# at the mobile screen to know IMEI no of your mobile.send the IMEI no to me and i will reply you with unlocking code.IF Problem not Solved SoPlease New Software install in the Phone Problem will Solved
How to format a nokia 6263 phone
1. Switch off your Nokia phone2. Now Press following key sequence *#7370# or *#7780#3. Enter Default lock code is 12345.4. While holding these buttons, press the power button and switch on the phone.5. Wait for message 'Format it
Unlock 6263
Many methods are there to unlock mobile phones among that codes are the best way because its safe for your mobile..........Get the unlock code for your nokia 6263 model mobile here
Superunlockcodes.com , it gives the easy instructions for getting the code for your mobile .........
I cant find the Puk code on Nokia 6263 ? so is my
Hello
Thank you for using Fixya!!
The PUK code requested is an unique code to each phone. At
the link below you will be directed to a tip i wrote on how to recover
your PUK code.
Click HERE to navigate.
Kind regards
Lock123
10/13/2011 11:52:23 PM •
Nokia 6263...
Answered
on Oct 13, 2011
I FORGOT MY NOKIA 6362
Try master reset codes for your phone by the way you can reset the security code and change new
