20 Most Recent
LG DLG2524 Gas Dryer Questions & Answers
Front loading dryer
The check filter light is just a reminder light and cannot be reset. Nothing to worry about. Just keep the filter clean before each use.
LG Gas Dryer Noise
Contact the manufacture at their web site and get a Support Rep. to assist you with dowloads of Manuals.
Dryer keeps saying check filter - lint screen is
Had the same problem. Filter was clean. Vacuumed out the area under the filter. Still had problem. Unplugged the dryer. Removed the hose vent (back of dryer) and checked the exhaust -- all clean. Plugged the dryer back in and was fine. Still going to check the vent to the outside for lint buildup.
My 10 year old electric
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
The dryer is taking a lot longer to dry now than
If your
dryer is not drying like it once did or if you just have nottaken the time to give yourself a
clean dryer in a long time then youneed to do that. At least once a year the
dryer cleaning should takeplace.
Lint build up in the
dryer duct is one of the main causesfor your dryer to fail.
Here is the rest of this tip about
DryerMaintenanceheatman101
6 YR OLD STACKED UNIT HAS GOT LOUD LOW GROWL LIKE
no the roaring sound you hear is the clutch assembly sounds like to me the transmission is going bad. The stack units have that problem after several years. Its up to you but just from my experience i would purchase a new one that way you get a warranty. just think if the motor was bad it would not run at all.
No power on lg gas dryer
Normal
0
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";}
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going
bad...
Here are a couple of tips that I wrote will help you to figure out why your
dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
How to re-install the LG DLG2524W Belt?
remove the top and front covers,then slightly lift the drum up and thread belt over and around the drum,then on the unit theres a drum belt routing diagram for the drum,motor,and the idler tensioner pulley
Dryer filter
Yes, it will, but you wouldn't want to run it this way. The airflow is designed with an amount of back pressure, provided by the air filter. If you take that away, you will change the whole pattern of flow. Plus, it keeps larger and possibly flammable fragments out of the the heat chamber of your dryer. The heat chamber is where the flames do their work heating the air before it is fed into the tumbler. Those fragments lodge in there, and you could have a fire on your hands someday. I personally wouldn't do it.
You don't say why you want to do this; I'll assume there is some reason. You might want to find another way before you run filterless.
Practice safe drying! Always use a filter!
My LG Dryer timer gets stuck on 6 minutes everytime
We had this problem three times. First two times we just removed,
cleaned and put back the moisture sensor (metal strips inside). The
last time we did as well but it didn't help. We phoned to a service guy
and he said unplug the power cord for 20-30 minutes. And it worked!
