20 Most Recent LG DLG3788W Gas Dryer Questions & Answers
Where can I purchase a LG DLG3788W start button
Searspartsdirect.com or repairclinic.com
1/15/2019 12:11:32 AM • LG DLG3788W Gas... • Answered on Jan 15, 2019
2answers
LG dryer is shorting
A seriously dangerous problem! Call a repairman immediately!
9/10/2016 12:40:49 AM • LG DLG3788W Gas... • Answered on Sep 10, 2016
LG gas dryer won't heat - u01 error
2/22/2016 3:10:17 PM • LG DLG3788W Gas... • Answered on Feb 22, 2016
0answers
Dryer stops running during cycle
What stops running, the heat or the drum? If it's the drum, check the centrifical switch on the motor.
7/21/2014 7:08:08 PM • LG DLG3788W Gas... • Answered on Jul 21, 2014
0answers
Kenmore dryer making a thumping noise
Your dryer has rolls on the drum and they are going bad and need to be replaced
3/24/2014 3:38:33 PM • LG DLG3788W Gas... • Answered on Mar 24, 2014
I have a code of "LE1" on the display, from the description on the code sheet it means thermistor open, what does that mean and how can i fix it
its a temperature sensor connected to the heating element about the size of small button. Usually straight forward to replace. If you do take the back off and replace it (maybe 2 off) make sure the back is replaced before you switch the heater back on to test it.
12/12/2013 9:03:44 PM • LG DLG3788W Gas... • Answered on Dec 12, 2013
What does thermistor open mean
thermistor is bad. normally closed if good. no current flow if in the open position. Replace.
12/10/2013 8:24:19 PM • LG DLG3788W Gas... • Answered on Dec 10, 2013
Not heating up and taking way too long to dry clothes
It could be igniter problem or main control board and dryer not igniting and not heating up and it is just cold air in the dryer
12/8/2013 8:27:40 PM • LG DLG3788W Gas... • Answered on Dec 08, 2013
It takes way to long to dry close, no it takes up to 5 hours to dry
if u look where the heat tube is there is thermostats one or more is burnt out
12/8/2013 2:43:33 PM • LG DLG3788W Gas... • Answered on Dec 08, 2013
Newer LG front load gas clothes dryer. power
if you hear the flame light but it doesn't stay on for a long time most likely you have lint blocked up in the dryer or in the vent linepull out the lint screen filter and look down into the duct that the filter slides into,if that's blocked you can try to stick a brush down in there and pull out as much lint as you can and then get a shop vac and set it up to blow and try to blow the rest of the lint out,if this doesn't work you have to pull the front of the dryer off and clean out the duct,also vac and blow out the gas tube and the motor and vac up any lint that's in the cabinet,unplug the dryer,remove the top,then the control panel and then the front panel.put it back together and then go out side and make sure the duct is clear no cage or screen,go back inside,remove the vent line off of the back of dryer,if it's a long run to the outside stick a leaf blower into the vent line and blow it to the outside,put it back together and you should be fine.this should be done once a year with a gas dryer so you don't have any problems with parts or how it's running and most important you won't have a fire.if you need anymore help let me know.
10/7/2013 9:57:40 PM • LG DLG3788W Gas... • Answered on Oct 07, 2013
LG Tromm dryer dryer number DLG3788W is not
Either there is a fault in the power supply to the heating coils, or the heating coils have burned out. A multimeter will come in handy at this point to check continuity across the terminals to the heating coils, and to test current supply to the coils. Be very very careful since you are dealing with 220 volts. If you do not feel comfortable doing it yourself, call an appliance repairman.
10/2/2013 6:21:06 PM • LG DLG3788W Gas... • Answered on Oct 02, 2013
The high limit safety thermostat keeps tripping, turning heat off in about 30 minutes. Put new one in other day and problem persists-any ideas of cause?
I just had a dryer with the same symptoms. Here's what I found. The one I had had a bad felt strip around the drum, allowing the lint to be sucked and blown places it was never supposed to go. I had to take the machine completely apart, because the fuse was doing it's job, and tripping because of overheating. This dryer worked fine once the felt was replaced. You may find there is a buildup of lint or an air exhaust blockage somewhere you never had checked causing this problem. Remember, it could be not only in the machine, but in the exhaust system between the machine and the air outside. Be blessed.
6/24/2013 3:04:15 PM • LG DLG3788W Gas... • Answered on Jun 24, 2013
LG DLG3788W Gas Dryer Logo
87 questions posted
Top LG Dryers Experts
Paul Carew
Grand Canyon Tech
Grand Canyon Tech
Are you a LG Dryer Expert? Answer questions, earn points and help others
View Most Popular
LG Dryers
  • LG Dryers
Most Popular Question
replacing thermostat part number
  • Dryers
