20 Most Recent American Standard Contemporary Kitchen Sink Liquid Soap Dispenser - 4305.20... Questions & Answers
Clogged bathroom sink
Try removing the **** Trap under the sink, there are two nuts one on each side. put a pan under the sink to catch the waste water in the trap first. ext loosen the nuts with a pair of channel locks or a pipe wrench turn the nuts counter clock wise direction till the nuts are loose slide the trap down and empty the contents of the trap into the bucket. Use rubber gloves so you don't get sick from germs. If the **** trap is plugged use a coat hanger to push threw the trap to get whatever is plugging it out. Rinse in a different sink, If it has the rubber gaskets I would recommend replacing the gaskets. Install in reverse. Do not over tighten the nuts or you will have to replace the parts. the trap looks like 2 opposing J .
10/16/2014 11:24:40 PM • American... • Answered on Oct 16, 2014
Does America have problems with war looming larger
NO!
9/17/2010 4:38:30 AM • American... • Answered on Sep 17, 2010
Forgot pasword
mcdevito75 here, you should be able to contact American Standard at 800- 442-1902 8A--6P EST. for your password.
7/13/2010 11:59:47 PM • American... • Answered on Jul 13, 2010
I have 2 American Standard deck mounted soap
All soap dispensers work on a siphon principal. There are o-rings inside these pumps and, over time, they dry out (even when surrounded by soap (which has an acid base)). Unless there is a way to dis-assemble these pumps and replace the o-rings, you may want to start looking for replacements.
5/16/2010 5:16:19 AM • American... • Answered on May 16, 2010
How do you put the liquid soap dispenser back
The "bottle" screws in from the bottom. The "pump" is inserted in the top. I usually fill mine from the top without taking out the bottle. Too much of a pain. Just make sure the large nut holding the hardware in place is secure before you start assembling the bottom and top. If it's loose, the whole thing will wiggle around. Good luck!
5/9/2010 11:22:57 PM • American... • Answered on May 09, 2010
I am trying to fix a dripping faucett of a 1970's
That's where a mechanic has a feel for things and just looks for any set screws or threads, a handyman might help with this for you.
3/28/2010 12:59:35 AM • American... • Answered on Mar 28, 2010
2answers
The sink dispenser won't dispense...
either the water is turned off, the pipe is blocked or the handle is stuck or broken. I would recommend that you call a plumber.
2/24/2010 4:28:10 PM • American... • Answered on Feb 24, 2010
The bottle that contains the soap for my sink
Hello. You will find that the bottle will come out once you remove the nut under the surface of the sink.
You have to get into the cabinet to do this. And, a faucet wrench, available at any hardware store will assist you greatly. Regards, joe
12/5/2009 1:31:27 AM • American... • Answered on Dec 05, 2009
Soap leaks from dispenser after use
sounds like a bad valve in handle, might be cheaper to just replace hadle buy the same one and just put in top that way you don;t have to climb under sink and loosen bottle
7/26/2009 2:50:40 AM • American... • Answered on Jul 26, 2009
I have 2 of these pumps.. one doesn't pump
no there is not a part you can buy,you must replace the whole unit.
7/22/2009 12:53:04 PM • American... • Answered on Jul 22, 2009
Plugged dispensor of the liquid soap at kitchen sink.
soak it in hot water and try pumping it every so often,should loosen liquid soap.
6/14/2009 2:57:51 PM • American... • Answered on Jun 14, 2009
Air switch randomly comes on by itself and I have to leave the breaker off
This could be caused by a faulty relay or switch in the control panel. It is best to have a qualified technician inspect the control panel and replace any faulty components. If the issue persists after replacing the faulty components, then it could be a wiring issue and a qualified electrician should be consulted.
2/22/2023 9:40:24 PM • American... • Answered on Feb 22, 2023
We have an American Standard 4035 elongated toilet. We want the water level in the toilet to be higher.
To make the water level higher in the pan, the outlet pipe must be higher.
6/29/2022 6:47:32 AM • American... • Answered on Jun 29, 2022
I have an American Standard 4035 dual flush toilet. How do I increase the water level in the bowl ?
Adjust the float on the fill valve
8/23/2021 10:14:08 PM • American... • Answered on Aug 23, 2021
Our American standard duel toilet takes to long to refill the tank and sometimes there is not enough water to flush just water down
Depends how old your toilet is, it may be a calcium build up problem on your little inlet pipe inside your tank, but first check your water shut off valve on left side of your toilet near the wall....It may not be open all the way OR the valve has an issue...
7/12/2019 11:28:54 PM • American... • Answered on Jul 12, 2019
My American standard champion 4 sings after I flush it, while it I still filling. Then stops when filled.
Hey, One thing is that maybe there might be some loose plastic shavings in the fill line. From the Factory? or maybe was inside the water line going to the toilet when you connected the line to toilet. Shut off the water and get some towels and something to catch the water and disconnect it from the toilet and use bowl or what ever to catch the water and slowly turn it on and see if anything comes out. Maybe if it is in the line inside the toilet it might fall out by lightly tapping on the fill line inside the toilet to help it fall out. Just a thought when you said it "Sings" that sounds like trash inside the line going to the filler tube and bowl, hey try it who knows it might work. Okay
7/12/2019 12:28:16 PM • American... • Answered on Jul 12, 2019
We have a wall mounted American Standard toilet from the 1970's. The tank has a crack in it. Is it possible to just change out the tank?
Hi, First, carefully remove your tank lid, and place it where it won't break or fall. Look for a four-digit number located on the back of the tank, near the water level mark. This is your tank model number. If the number starts with a two, it is a one-piece toilet. Then....visit this link: https://www.americanstandard-us.com/parts-support/faqs/toilets Good Luck!
5/6/2019 8:23:04 PM • American... • Answered on May 06, 2019
American standard hands free toilet battery pack doesn't work
More likely the sensor has malfunctioned.
11/24/2018 6:54:16 PM • American... • Answered on Nov 24, 2018
American Standard Contemporary Kitchen Sink Liquid Soap Dispenser - 4305.20... Logo
14 questions posted
Top American Standard Home Experts
john h
Mike Cairns
Mike Cairns
deton8 von Splosion
Are you an American Standard Home Expert? Answer questions, earn points and help others
View Most Popular
  • American Standard Home
Most Popular Question
clogged bathroom sink
  • Home
