20 Most Recent LG DLE3777 Electric Dryer Questions & Answers
2answers
Why would a dryer be leaking water at the bottom?
look for a restricted vent . and a cold floor or room . this would cause condensation and would leak from inside / causing leakage on floor in or around the dryer .. hope this helps . pls leave feed back .. mm
11/17/2021 1:30:58 AM • LG DLE3777... • Answered on Nov 17, 2021
My lg dle377w dryer sounds like a train goin by on the tracks. what could be the problem
You posted in 2013, I just bought my in 2019 and it still sounds like a chug chug train. Annoying but sir Topham Hatt may have a fix one day.
1/28/2019 4:04:52 AM • LG DLE3777... • Answered on Jan 28, 2019
Can I test the limit switch on my LG TROMM
if it has continuity it's good and isn't the problem,if the dryer starts and stops running after a minute you could have a bad computer board,when it stalls try tapping on the board and see if it starts,also unplug it and look at the board you might see something cooked on it or a soldier joint melted.
12/26/2017 5:38:30 PM • LG DLE3777... • Answered on Dec 26, 2017
I have the drum roller
Check out videos on repairclinic.com or appliancepartspros.com or YouTube.com
8/5/2017 5:50:18 AM • LG DLE3777... • Answered on Aug 05, 2017
2answers
We have an LG Dryer model DLE3777W. My husband is
Google the make and model see if you can down load a manual for this which will give you details on how to put the seal back, but not with a hammer .
4/13/2017 5:14:11 AM • LG DLE3777... • Answered on Apr 13, 2017
How do I clean the interior of a LG DLE3733W Dryer?
Hello Mary; My name is Peter. I am a retired field service appliance technician. Both LG & Samsung appliances are a service technicians nightmare. They have the highest service call rate, the most expensive parts and take the most time to access and repair parts. I will give Samsung a thumbs up on televisions and stereo's. It would be nice if consumer reports would survey field service technicians rather than owners and get the real story. Believe me you do not want to disassemble. You are going to end up calling a service company to put it back together and get a $250.00-$300.00 bill. Ok, what can you do? Air flow blows 95% of the lint out the connection to the outside air discharge behind your dryer. 1.) Pull your dryer out to the point that you can get behind it. 2.) Unplug your dryer. 3.) Hot air distribution manifold - There are several screws holding this on. There are no hot electrical components to be concerned with. Remove this. 25706565-0y12ph2q2eyplwuhbpotrs5a-2-0.jpg In the bottom rounded part is where you get plugged up. Clean this out. 4.) Hot air discharge at the wall - Usually, the connector vent hose is held on with band clamps. In this case you need a flat heat screw driver to loosen and remove the vent hose. 5.) With a vacuum cleaner hose, vacuum out the hole in the wall as far as you can reach. Then, vacuum out the air discharge as far as you can reach. The hot air blower wheel in in the front of your dryer. 6.) Before reinstalling the hot air distribution manifold and connecting the out side air duct. Plug your unit in and turn your dryer on and run for 5 minutes to blow out excess lint. The hot air distribution manifold and the outside air duct create a back pressure. This way your blower wheel will run full open.
5/21/2015 10:15:02 PM • LG DLE3777... • Answered on May 21, 2015
After setting timer then hit start button timer display and start button just blink and nothing happens
Sounds like the main control board of your machine is faulty.
3/29/2015 9:54:03 AM • LG DLE3777... • Answered on Mar 29, 2015
Lg dryer keeps blowing thermal fuses
check you entire vent system and make sure there is a clear airflow all the way to the outside. A simple test is disconnecting the vent hose and letting the air flow into the open room. If works OK, you definitely have an airflow problem.
2/2/2015 8:02:47 PM • LG DLE3777... • Answered on Feb 02, 2015
Lg dryer fuse keeps blowing but the heating element and thermostat all have continuity
I have been using an LG domestic dryer in a commercial application (motel) for 5 years and the only problem has been a lint build up inside the dryer because of an improper vent installation. The problem is likely in the dryer drum motor, it runs for a short time heats up because of bad motor bearings, improper motor cooling or bad drum bearings (motor drives the drum) increased heat = increased amperage= blown fuse. Motor should go out on overload but it may blow a fuse first. Is the fuse in the electrical panel or in the dryer? Try turning the dryer drum by hand and check for resistance, there shouldn't be much. The motor needs to cool so pull the dryer panels apart and vacuum the inside first and make sure the motor and interior has been thoroughly cleaned. Try this for a quick fix first.
2/1/2015 2:54:36 PM • LG DLE3777... • Answered on Feb 01, 2015
Lg dryer keeps blowing thermal fuses we have checked the thermostat and the element all have continuity
The thermostats (outlet and on element case) can still allow the heat to go to high, restricted airflow will also cause them to go.
2/1/2015 4:55:56 AM • LG DLE3777... • Answered on Feb 01, 2015
Lg dryer keeps blowing fuses the element and thermostat all have continuity
It could still be grounded/shorted, the elements will weld themselves to their case or themselves. Continuity should be 8-20 ohms.
2/1/2015 4:53:25 AM • LG DLE3777... • Answered on Feb 01, 2015
No heat, everything else ok. Cooling light is
It could be the high limit switch is open. Most of these are non resettable and have to be replaced. Check vent piping and filters for lint that may be clogging the vent system and causing the overheating. Replace the high limit. If that does not solve the problem the element may be burned out. Hope this helps Bob
12/17/2014 3:38:42 PM • LG DLE3777... • Answered on Dec 17, 2014
Puff of smoke from display
Short in board or behind. Do not run the dryer. Remove back cover and look for obvious black marks. Replace as necessary. Dryers get banged around and hopefully it is an easy find. It could be the board itself. I'll hope for a small short that can be fixed with electric tape.
1/13/2014 5:29:52 PM • LG DLE3777... • Answered on Jan 13, 2014
The dryer starts running for only 5 to 7 seconds
Did you ever find out what was the problem? Mine does the exact same thing.
11/3/2013 8:49:24 PM • LG DLE3777... • Answered on Nov 03, 2013
I HAVE A LG DLE3777W DRYER THAT COMES ON, RUNS FOR
tighten the ac cord possible replace it sounds like a loose connection somewhere
10/31/2013 12:14:04 AM • LG DLE3777... • Answered on Oct 31, 2013
LG DLE3777 Electric Dryer Logo
105 questions posted
Top LG Dryers Experts
Paul Carew
Grand Canyon Tech
Grand Canyon Tech
Are you a LG Dryer Expert? Answer questions, earn points and help others
View Most Popular
LG Dryers
  • LG Dryers
Most Popular Question
dryer door opens in middle drying
  • Dryers
