20 Most Recent Schiller Cardiovit At 2 Light Ecg Machine Questions & Answers
2answers
How do I change from cm/kg to inches/lbs?
No can do. Cm is distance and Kg is weight. Inches are distance and pounds is weight. Thats like "how can I convert an orange into an apple. RJ
9/29/2017 2:05:07 AM • Schiller... • Answered on Sep 29, 2017
2answers
When auto print is pressed the machine blanks out and nothing prints
Try this link to slide share for a colour rendition of the user manualhttp://www.slideshare.net/DiscountCardiology/schiller-at-2-ekg-manual
4/17/2015 2:48:25 PM • Schiller... • Answered on Apr 17, 2015
Schiller at-2 macine, autoprint function
Likely your paper is loaded incorrectly or is incorrect for the unit. The auto print format depends on the position of the black "que" mark in the paper, but the manual mode does not. Be certain that the paper is correct for you unit. If that isn't it, then you que sensor could be dirty or defective. THis would require shop level repair, as dis-assembly of the unit is required.
4/17/2015 2:34:39 PM • Schiller... • Answered on Apr 17, 2015
Why won't it turn on?
Sounds like you need a new battery. When they go dead you will still see the green light but it will not turn on or only on for a second.
4/17/2015 2:21:52 PM • Schiller... • Answered on Apr 17, 2015
2answers
I have a AT2 Plus machine and cannot find my
To change the Time :
- Firstly, press the following key sequence : ALT, 9, 1, 1
- Then, enter the time (HHMMSS)
- Finally you'll hear the confirmation beep
To change the Date :
- Firstly, press the following key sequence : ALT, 9, 2, 2
- Then, enter the date (DDMMYY)
- Finally, you'll hear the confirmation beep
9/26/2013 5:41:07 PM • Schiller... • Answered on Sep 26, 2013
3answers
High, I have a Schiller
hi,
Your machines thermal printing head have some problem. Thats why it give printouts very light. Not possible to repair thermal head. You have to replace it.
ok
12/13/2011 1:43:30 PM • Schiller... • Answered on Dec 13, 2011
My machine will not turn on
Greetings. The schiller AT2 is battery powered. It will power on when plugged in however even with a dead battery, but if the battery is REALLY bad, we have seen it load the power supply preventing power up. On the top of you unit there is a small green "AC" indicator that should be illuminated when the at2 is plugged in. If it doesn't, your power cord might be bad, try a new one. If that doesn't fix your problem I would try at least to replace the battery. The battery requires dis assembly to replace, and there are three cable attaching the top case to the PC board. If you pull it apart to far without detaching the cables, you will do expensive damage. Also the removal of top case exposes high voltage, so this should never be undertaken a. with the unit plugged into a wall outlet, or b. By an unskilled individual. I would recommend that you find a local bio-medical contractor, or other service company, and have the battery changed. If your chosen contractor replaces the battery and the problem remains, your main board likely needs replacement, again by a qualified individual. Be warned however this in a very expensive part. There are several other possible problems, but very few that are operator serviceable. Best of luck!
11/21/2011 2:21:34 AM • Schiller... • Answered on Nov 21, 2011
2answers
The schiller At-2 we have in the office is acting
HI,
check the paper u have inserted. it should be Schiller original paper with page marking. also clean the paper sensor. u can see the paper sensor near the side of printing head. a small square portion. clean it with an ear bud, don't use any solution for cleaning only ear bud.
ok
7/19/2011 7:12:56 PM • Schiller... • Answered on Jul 19, 2011
At-2 lite model not printing
hi,
check the paper you have inserted. if the paper quality is bad then the printing can become bad. Use schiller original paper.
if again printing is bad then the thermal printing head of you machine is faulty or the. you have to replace the same.
ok
4/18/2011 3:47:06 AM • Schiller... • Answered on Apr 18, 2011
3answers
Upon pressing the AUTO PRINT the EKG tracing only
Have you selected the right program?
3/5/2011 5:26:48 PM • Schiller... • Answered on Mar 05, 2011
One of my stylus seem out of contact with the
hi,
there is a pressur adusting facility inside for the thermal printing head. u can adjust it for quality printing. for adjusting the same i will prefer use the help of a qualified person.
ok
12/23/2010 10:17:27 AM • Schiller... • Answered on Dec 23, 2010
PRINTER HEAD ASSEMBLY NOT WORKING NO PAPER FEED
1001 Questions I could ask to solve this dilemma but one will do, manufacture and model please?
3/16/2010 4:11:04 PM • Schiller... • Answered on Mar 16, 2010
I need to put the date in it. As when program
I think I have the user guide for this. please send me an email and I will send it over to you. [email protected]
10/26/2009 4:19:16 PM • Schiller... • Answered on Oct 26, 2009
Printing 3 leads only not 12
Hello medico001, The info on the Schiller web site states an option of 12 lead for model Cardivot AT. If your unit has this option only the automatic selection will deliver the 12 lead print. For futher info select the web site http://www.schilleramerica.com and click on 'Contact Us'. This should direct you to someone local. Good luck.
11/4/2008 2:22:16 AM • Schiller... • Answered on Nov 04, 2008
How to print only 1 sheet in Schiller at 102 ecg machine?
Navigate to the ECG settings using the control panel or keyboard. Look for the option related to print settings or number of sheets. Select "1 sheet" or the equivalent option. Start the ECG recording for the patient. The machine will now print only one sheet of the ECG recording. Remember to consult the AT-102 Service Handbook for detailed instructions specific to your machine. AT-102 G2 (IN) ° (schillerus.com) Thermal Recording Chart Paper for Schiller CARDIOVIT AT-102 Recorder (schillerservice.com) 0110_EN_AT102_LQ.pdf (schillerservice.com)
3/9/2024 6:05:05 AM • Schiller Medical • Answered on Mar 09, 2024
Hi!I have problem with the SCHILLER AT-2 machine. The S Wave is not plotted on paper. How to fix it?
Try rebooting the machine 70@;then flush the print head. If it still doesn't print you will have to replace the head. There are some online companies that can guarantee to flush it.
4/4/2019 7:27:15 AM • Schiller Medical • Answered on Apr 04, 2019
Schiller AT-101 EKG, print almost the whole EKG cycle until it got to the 2 last pages (with all the details) then it suddenly stops. What I need to check and fix in order to fix this issue
not familiar but have you set up the print menu we're it requests the number of pages to be printed! Best i can suggest.
10/30/2018 4:54:37 PM • Schiller Medical • Answered on Oct 30, 2018
I need schematic of Schiller cardiovit AT-101
User manual and service manual in case that assists you. https://www.medwrench.com/equipment/2690/schiller-cardiovit-at-101 Possible vendor contact phone number to ask for assistance: https://www.med-electronics.com/Schiller-CARDIOVIT-AT-101-EKG-p/9.080000c.htm
10/17/2018 1:12:45 AM • Schiller Medical • Answered on Oct 17, 2018
3answers
Our schiller AT-102 Plus does not show trace on the screen as it does normally after the leads are connected. what could be the trouble?
Our company objective is to sell high quality medications only at affordable prices, and to satisfy as many customers as we can. That is why we offer lower prices compared to the other merchants. Buy Tadalista Professional Buy Tadalista Professional AllDayGeneric com My Online Generic Store
4/12/2018 7:00:37 AM • Schiller Medical • Answered on Apr 12, 2018
Schiller Cardiovit At 2 Light Ecg Machine Logo
32 questions posted
Top Schiller Medical Experts
john h
ADMIN Andrew
ADMIN Andrew
Don A
Don A
Are you a Schiller Medical Expert? Answer questions, earn points and help others
View Most Popular
Schiller Medical
  • Schiller Medical
Most Popular Question
schiller 2 in office acting
  • Medical
