20 Most Recent
LG L1004R Air Conditioner Questions & Answers
Need to turn on heater
Toget proper heat, keep your temp setting at 30+ degree and also mode in "heat"position. If still no heat, check your heating sensor for closed circuit by anOHMs metre.It it's with RV, check power to RV.If it's with heatingelement check power to element. If power is there but still no heat meanselement defective. Replace new heating element. Thanks.
It smells like burnt plastic after 30 min
is it new? how old is it? burnt plastic is the smell a bad motor produces. dont worry, i dont think it will cause a fire, but a fan motor on its way out will stink!
if its relatively new, return it. if not, get a new one!
Circut breakers
Is it after it has ran for a while or tripping every time it comes on? If after it runs awhile check your wire tightness at the breaker and at the unit. Loose wiring will heat up a braker and trip it. Also check to see that the rating of the unit and the breaker are matched.
My LG air conditioner is saying water fl what is that and where can I find it? I cannot find the book.
The FL error usually means that there is excess water in the drain pan. Look for the drain plug cap at the bottom of the back of the air conditioner. Remove the cap and tilt the air conditioner so that any water in the drain pan will run out. If the room is extremely humid and the air conditioner is set to Cool, this is normal. To reduce the water level issue, set the fan speed to Low. If the air conditioner is in the Dry (dehumidifying) mode, try setting it to Cool. Alternatively, consider using a hose if your unit allows for a continuous drain.
Unplug the air conditioner for at least 10 seconds to reset the unit if the error persists. If the drain pan is dry or the error recurs before more water fills the drain pan after the reset, then the air conditioner needs service.
Please add a comment with the model number of the unit if you need help finding the drain pan cap. I hope this helps.
I have error code ch 09 displaying on my
The error codes are not all the same. They are different for different models.
THIS IS NOT A SOLUTION....
This is a "Clarification request"
Can you please locate and post your LG model number here so we can help you properly and professionally.
LG air conditioner
You have to try resetting the system. First turn the breaker off for the condenser and wait about 20 seconds. After you turn it back on the system should reset. Also What is the model of your air conditioner. With out that information i cant help you with your ac repair problem
Check us out online at
AC Service Delray Beach Fl
Foutcode ch 24 bij LG airco
Question edited for clarity and translated to English.
A CH 24 error code indicates a pressure switch error. To Resolve: Make sure the air filter in the unit is clean. Remove any items or reposition the unit so that the air flow is not obstructed.
Apr 25, 2023
Lg dual inverter stuck in defrost
It sounds like you were experiencing an issue with one of the indoor units on your LG dual inverter air conditioner, where it was stuck in defrost mode while the other unit was working properly in heating mode.
It sounds like you've already replaced the control board of the indoor unit that was stuck in defrost mode and it fixed the problem. The control board is responsible for controlling the various functions of the air conditioner and it is a common cause of malfunction in air conditioning systems.
It's great that you've been able to fix the issue, but if the problem comes back or you're experiencing other issues, it's best to contact LG's customer service or a professional technician for further assistance.
It's important to note that troubleshooting and repairing air conditioners can be dangerous, especially if you're not familiar with the device, so it's best to contact a professional technician if you're not comfortable working with it.
LG 4 zone Mini Split error - CH35 triggered with specific Wall Mount.
These units cool better than they heat, and if the temperature ever drops far into minus 'C digits, they don't work at all.
I have found that turning off all power for a minimum of two hours will reset most errors,. When you switch the breaker back on, you will hear relays clicking as part of the self testing. Wait 15 minutes before operating the unit.
It sounds like your installer doesn't want to deal with you any longer. The engineers get very basic LG Service training, so at stages they are completely lost. I was advised not to buy LG and went with Fujitsu, but they have their own problems as it seems they all do!
Phone LG Support on Monday and ask their advice, don't let them just say call for service. Tell them you want to speak with a technician that does the training sessions and seminars.
LG Art Cool Gallery version A12AW1 won't start heating?
Question edited for clarity and spelling 'Gallery' and toss in some CAPS.
Question moved from LG Office Equipment Category.
Sorry for the delay in getting back to your question.
Try disconnecting the power at the breaker for at least 2 hours and preferably overnight. This fully resets the units and it will do a Self Test when you switch it back on. Wait 15 minutes before operating it. 5 Blinks is a loss of communication.
Fault Codes for all LG wall mounted and Artcool split system
airfusion.co.uk
https://www.airfusion.co.uk > fault-codes-all-lg-wall-...
Fault code C5, CH5 or 5
flashes This fault code indicates a communication error between the indoor and outdoor units. If there is a communication error fault ...
Missing: stops ' Show results with:
stops
People also ask
Why is my LG cooling light flashing 5 times?"); display: inline-block; height: 24px; width: 24px;">
Why is the light flashing on my LG air conditioner?"); display: inline-block; height: 24px; width: 24px;">
How do I reset my LG air conditioner?"); display: inline-block; height: 24px; width: 24px;">
What is E5 error on LG portable AC?"); display: inline-block; height: 24px; width: 24px;">
Feedback
[LG Air-Conditioner Error Codes] Checking code CH53
LG Electronics
https://www.lg.com > Home > Support Home
Jun 9, 2023 - The second LED indicates error at 10's digit. Ex) After the second LED blinks 3 times with certain interval, if the first LED blinks 5 times .
My lg split ac non inverter is working fine but missing command beep
- Check the remote control: Look for a button on your remote control labeled "Beep" or "Sound". Press this button to turn the beep sound back on .
- Check the settings: If you can't find a "Beep" or "Sound" button on your remote control, check the settings menu on your AC unit. Look for an option to turn the beep sound on or off and make sure it's turned on .
- Reset the AC unit: If neither of these steps work, try resetting your AC unit to its factory default settings. To do this, turn off the AC unit and unplug it from the power outlet. Wait for a few minutes and then plug it back in and turn it on .
If none of these steps work, it's best to contact a professional or LG's service center for further assistance.
I hope this helps!
LG Portable AC has E9 error code displayed.How to fix this?
have you cleaned filter a regular basis? dirty filters will cause low air circulation. go to long and the evaporator coil is dirty and plugged and will require cleaning. There is no E9 code listed the E5 code describes what you have. Have you been emptying water collection tank?
https://www.lg.com/ca_en/support/product/lg-LP0821GSB
