20 Most Recent Cooper Wiring Devices ACE6001V-K "ACE" ROTARY DIAL DIMMER Questions & Answers
How do you wire a GFCI light switch and outlet
If I understand correctly, you are replacing a single switch that has two wires.
You want to install a switch/plug-gfci similar to one shown below.
You are working on wires inside a box:
To wire this kind of device you need at least 2 cables entering the box.
Each cable has a black-white-ground wire.
Cable 1) One cable comes from breaker box. This is the Hot cable
Hot cable has black-hot-from-breaker & white-neutral-from-breaker
Cable 2) One cable goes to the Load (light, fan motor). This wire is controlled by the switch. This is the Load cable
Load cable has black-to-load & white-to-load.
Leviton combo GFCI and Switch
There are 2 screws on either side of switch
There are 2 screws to either side of plug
There are two wires on back of device
2 screws on either side of switch: there is a brass-colored screw and silver-colored screw.
Black-hot-from-breaker connects to brass colored screw on side of switch
White-neutral-from-breaker connects to silver colored screw on side of switch
2 black wires on back of device
Black-to-load connects to black wire on same side of switch as brass-colored screws
White-to-load connects to black wire on same side of switch as silver-colored screws
2 screws on either side of plug
These screws are used when your box is a 'junction' box that feeds wires forward to another box ... for example you have 4 receptacles in a room, the cable enters first box and then goes to the next box and to the next box. Suppose your switch was one of the boxes. Wire arrives from a previous box (this is the Hot cable, every box has 1 Hot cable). Your switch box sends one cable to the Load (light, fan etc), but it also sends another cable to the next box which has a receptacle or another switch.
If your box has a third cable that feeds forward to other boxes, then the screws on either side of plug are used. The black-to-next-box goes to brass screw. The white-to-next-box connects to silver screw.
And all further boxes and devices are protected by the GFCI device.
If you need more information, please answer back and I will help.
10/28/2014 12:31:14 AM • Cooper Wiring... • Answered on Oct 28, 2014
Como conectar los cables son 4
Mi espanol is not perfect: Use google translateCopy following link:Dimmer will be same as single pole timer:http://waterheatertimer.org/How-to-wire-timers.htmlAlso en espanol:http://waterheatertimer.org/Wire-dimmer-en-espanol.txtAdd a comment If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
5/24/2013 9:29:13 AM • Cooper Wiring... • Answered on May 24, 2013
0answers
2answers
I am installing GFCI receptacles in our boat and
If the test button pops the circuit when you press it, then it should be working properly, If it doesn't then it's not working.
1/18/2012 1:49:28 AM • Cooper Wiring... • Answered on Jan 18, 2012
I have an electric box
You have a combo light switch and GFCI.
It sounds like you are 1 wire short.
Where is the wire that goes to the light?
The black wire should be Hot, the white wire could be the Neutral or the could be the wire going to light.
The Black hot wire connects to dark-colored or brass screw on one side of device. This screw should be labeled Line.
You need a white Neutral line that connects on silver-colored screw that is located opposite where black wire connected.
The switch controls a light ... but you need another wire going to the switch.
Add a comment. Post a photo on Imgur.com and add that to your comment.
11/22/2010 12:42:58 PM • Cooper Wiring... • Answered on Nov 22, 2010
Seeking the CWL1420P wiring and assembly instruction sheet
The sell sheet for this product shows this is a NEMA-14 Twist lock plug rated for 120V - 240V wiring.
To wire the plug:
G is for ground W is for Neutral
The hot wires connect to X and Y
This is simple for 240V ... your red and black wires connect to X and Y, the ground to G, and the white neutral to W
For 120V circuit, the G ground and W white neutral remain the same. I think the black hot wire is X.
A simple tester in the receptacle can confirm this before plugging in the twist-lock
10/9/2010 6:52:48 AM • Cooper Wiring... • Answered on Oct 09, 2010
How to install a 3 way plug for stove
If I understand correctly, your stove plugs into the wall.
Your stove plug looks similar to one shown
Review wires inside wall.
There are 2 hot wires which are red and black
There is 1 neutral wire which is white
And there is a bare ground wire
Connect wires so they match image above.
2 hot wires, black and red go across from each other
White neutral connects to flat prong on top
Bare ground connects to round prong on bottom
Older wiring might not have both white and ground ... if you do not have both, then connect the wire you have to the flat prong on top
10/9/2010 2:58:09 AM • Cooper Wiring... • Answered on Oct 09, 2010
How to wire a gfci
Are you tryng to control this GFI with a three-way switch circuit? Wire it like you would a light but put the gfi where the light fisture would be. Circuit on the side of a three way switch box (the box the switch comes in.).
8/29/2010 8:35:21 PM • Cooper Wiring... • Answered on Aug 29, 2010
Trailer plug wiring diagram for 2002 ford F150
Here color codes for old f150, most are the same:
Light green/orange left stop/turn
Black/pink backup lights
Orange/Lt blue right stop/turn
Brown running lightsor Tail (markers)
Black = Ground
Green with white stripe LH Turn
White with blue stripe RH Turn
Here a forum on new model wiring.
This link can also help: http://www.accessconnect.com/trailer_wiring_diagram.htm
8/18/2010 11:27:09 AM • Cooper Wiring... • Answered on Aug 18, 2010
I have a switch that does not have any connecting
Sounds like you have bought a 3-way switch, this meets light can be operated at two locations. You need a single way switch, operates only at one point.
7/9/2010 3:22:37 AM • Cooper Wiring... • Answered on Jul 09, 2010
Power comes from light to switch.want to wire in
OK .. for this to work, you would need to confirm that the power cable is also in this wall box. So in that wall box you need the existing power cable, the existing light cable, and a new light cable. All the cables being 2 wire with ground. Then just jumper the black power wire top the new switch, and connect the new light , black wire to the switch, the whites will all be together ..
If there is only one cable in this wall box , then the power is run to some other box and you need a neutral for the new light. That may mean rewiring the power tyop get it to the wall box, or rewing the new light to get power from it.
Please Vote !!
5/14/2010 3:39:46 PM • Cooper Wiring... • Answered on May 14, 2010
Trying to uninstall a light switch. The two black
Of course you have the power turned off, right? Assuming you don't plan to re-use the old switch, just cut the wires. Your wires are probably plenty long enough if your cut them as close to the switch as possible. Then you can strip then new ends of the wires. It's easiest to strip the wires using a stripping tool, but it's not necessary to go buy one, as you can do this easily enough with a knife. Good luck, and thanks for using FixYa. Al Kupchella
4/21/2010 3:24:34 PM • Cooper Wiring... • Answered on Apr 21, 2010
Need to wire a 3 way switch with three lights
http://www.forteelectric.com/3WayBook.html
follow the link above or click on it and it will take you where you need to go so you can wire your switches correctly . Good luck and you're welcome . 2 cool Rick
4/19/2010 5:09:54 AM • Cooper Wiring... • Answered on Apr 19, 2010
I have a cooper triple single pole switch
Any switch always ONLY Breaks and Makes, the PHASE wire, the Neutral is COMMON.. So you can either join the phase wires to ALL contact terminals on one side, and then take SEPARATE phase wires out to each "Load" on the "Other"side, terminals. OR run a separate wire at each side, for each terminal .from Breaker box and out to the load.
3/18/2010 11:17:03 PM • Cooper Wiring... • Answered on Mar 18, 2010
Light Switch trips breaker when on, power 2 lights in off posit.
sounds like you have installed the wrong switch.
There are 2 way, 3 way and 4 way switches.
If more then one switch turns the light on - it cannot be a single pole switch you install.... it must be 2,3,or 4.
Ensure you have the proper switch.
Thanks!!
3/16/2010 3:08:40 PM • Cooper Wiring... • Answered on Mar 16, 2010
Can I get help rewiring a lamp plug here?
Connect the black wire to the narrow prong, the white wire to the wider prong and the green wire [ if you have one ] to the round prong and it will be correct. hope this helps you. Jeepfxr
1/21/2010 1:39:49 PM • Cooper Wiring... • Answered on Jan 21, 2010
Cooper Wiring Devices ACE6001V-K "ACE" ROTARY DIAL DIMMER Logo
25 questions posted
Top Cooper Wiring Devices Electrical Supplies Experts
Sean Wright
Sean Wright
john h
Are you a Cooper Wiring Devices Electrical Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Cooper Wiring Devices Electrical Supplies
Most Popular Question
electric box
  • Electrical Supplies
