20 Most Recent
Kohler Santa Rosa Compact Elongated Toilet with Toilet Seat, Cover and Left Questions & Answers
The toilet is only 2 months' old. The water keeps
Remove the top of the water tank.
check to be sure that the flush cover (about in the center of the tank) can close all the way. It seats into a 2 inch hole - and must seat all the way around. If it fails to seat, then the fill valve (on the left side of the tank) will continously let water into the tank.
As a starter experiment, you may try just turning whe water off at the wall shut off. Then inspect the tank to confirm that it is losing water.
If confirmed, then the above solution is correct.
If it is not losing water, then the fill valve is faulty and will need to be replaced (it is allowing water to over flow into the "OverFlow" tube.....
I recommend that you keep the water turned off at the wall until the toilet is needed - and the problem is repaired.
What is "Grey Water"?
In some areas with water shortage issues, in order to conserve levels of potable water, some installations use grey water for toilets. Grey water is waste water produced from processes such as washing dishes, laundry and bathing.
Need password for a stolen file
Okay. The question is a bit lacking in details. Password for what? Password ON what? Where was the file stolen from? Who stole the file? What is the file content. What is the file extension (the bit after the file name and the period file_name.what)?
All questions need to start 'make model (what it is)' first 3 words. And then a clear question.
For the 13 people that have tagged this 10 year old question, it is better to post your own question.
2/7/2024 6:03:08 AM •
Kohler Home
Answered
on Feb 07, 2024
