20 Most Recent
Lincoln Electric LE 83180 Century Professional MIG/Flux Wire-Feed Welder Questions & Answers
No ark
no ark
prolly means no bible
I have bought a ya205
probably circuit board, i might have one , email me user name hoss805 on layitlow.com
Im looking into getting a mig and have come across
No, it's not going to be equal to the Lincoln in all ways- but if Lincoln built it it'll be a decent machine.
In all honesty, if you can only have one welder it should be a stick welder. Mig welders are full of problems and, while ideally suited to 8 hour a day 7 days a week use, can be finicky as heck when used infrequently.
The stick welder allows you to work in all positions and all conditions, it's generally cheaper than Mig welding and it's usually faster.
lp
My wire feed quit feeding wire what do i need to
Hi:If your drive rollers are moving but can't push the wire all the way to the end of the gun, your problem could be the liner in your gun and/or the contact tip. Try to replace both. If your drive roller are not moving then check the trigger of the gun.
Broken wire speed switch
You can fix it yourself, take the potentiometer (also known as reohstat) out.You will need to open the machine and take the knob off to free it out. You can take the old potentiometer to any electrical shop, or go to your nearest welding shop/store I will recommend praxair store.
