20 Most Recent NexxTech 175W Power Inverter Questions & Answers
My nextech 175 watt power inverter stopped working. is there a fuse inside that I can replace?
If it is a cigarette lighter outlet check it it may unscrew if it does there should be a fuse
4/15/2021 7:06:43 PM • NexxTech 175W... • Answered on Apr 15, 2021
The fault light is on, on my Go Power! Inverter
Contact manufacturer on the web. Look for Support/Downloads/Manuals.
1/4/2019 7:43:27 AM • NexxTech 175W... • Answered on Jan 04, 2019
I bought a Nexxtech 175 watt inverter to power my laptop. It worked fine in my truck in the store parking lot but won't work in my tractor where I really need it. It works from the power point or the
It could be any of a number of things, but the first 2 guesses I am going to make are: 1) The contacts in the cigarette lighter jack in the tractor are corroded; or 2) the wires that power the cigarette lighter jack in the tractor are too small of a gauge to provide enough current flow without a voltage drop. This one can be tested by popping the cigarette lighter jack out of the dashboard while still wired (carefully, you don't want to cause a short-circuit), and then plugging in the inverter and measuring the voltage with a multimeter going INTO the lighter jack. It should be at least 11.5, preferably 12, Volts. Test both before and after the inverter is plugged in. If the after reading drops too much, then you know you need a bigger gauge wire feeding the lighter jack.
7/24/2014 6:40:28 AM • NexxTech 175W... • Answered on Jul 24, 2014
0answers
I cant get an image from my Sony DVD player onto
Return the universal remote, and buy a R.C.A. universal
5/26/2011 5:31:53 AM • NexxTech 175W... • Answered on May 26, 2011
2answers
I plugged in my nx2 to my car green light was on n
check fuse for cig lighter
2/3/2011 4:17:51 PM • NexxTech 175W... • Answered on Feb 03, 2011
175 watt 350 peak inverter 12v dc to 110 ac need
Hi
15/16 amp would be recommended.
You could to try a 20 amp, but you will risk overheating and the possible failure of the vehicle circuit fuse.
Regards
1/30/2011 10:06:07 PM • NexxTech 175W... • Answered on Jan 30, 2011
The red fault light is luminated. How do I reset
it should rester when you turn off the invertor
4/5/2010 11:00:39 PM • NexxTech 175W... • Answered on Apr 05, 2010
I HAVE USED THE NEXXTECH 175 WATT POWER INVERTER
have you charged it,and check if the battery is still ion good condition
2/26/2010 12:28:23 PM • NexxTech 175W... • Answered on Feb 26, 2010
2answers
Ruining lap tops
175 W inverter is not enough power for your computer and most of the cheap inverters do not put out a true sine wave. Buy one rated at least at 400w. Then it will output continuously at 300w. That should be sufficient for your computer. Your 175 w inverter is overtaxed then the voltage drops increasing amperage and burning things out.
1/2/2010 5:13:24 AM • NexxTech 175W... • Answered on Jan 02, 2010
Fault light comes on when unit is plugged in
Car battery may be too low to run it.
8/19/2009 2:40:13 AM • NexxTech 175W... • Answered on Aug 19, 2009
Nexxtech 32gb thumb drive not detectable. Can't format.
your computer cant handle it,try it on another comp
5/15/2015 8:55:30 PM • NexxTech... • Answered on May 15, 2015
I have a Keb 12F5 that shows E.EF external fault. How to solve it please?
It appears to be something to do with this https://www.google.com/search?q=keb+12f5+that+shows+E.EF+external+fault 7.13.1.6 External fault With Pn.04 "Ext. fault input selection", one or more digital inputs can be programmed which can trigger the error "31: ERROR! External input" (E.EF). With Pn.03 "E.EF stopping mode" , the response of the inverter to the digital input is defined. With Pn.65/ bit 1 "2: Pn.04 = E.UP https://www.keb.su/doc/Instrukciya%20F5-A_E_H%20ver.4.0%20(ang.).pdf ..
2/27/2024 6:55:25 AM • Electronics -... • Answered on Feb 27, 2024
How do I connect my laptop to the TV?
Back in 2014 it wasn't so easy. Laptop with an HDMI port and a smart television with HDMI. ..
2/27/2024 6:47:57 AM • Electronics -... • Answered on Feb 27, 2024
2answers
I have an Emerson Quiet Kool Rooftop R/V air
I have a quiet cool roof top air conditioner and am looking for parts for it.
2/9/2024 5:25:36 AM • Electronics -... • Answered on Feb 09, 2024
NexxTech 175W Power Inverter Logo
Popular Tags
22 questions posted
Top NexxTech Electronics - Others Experts
 Grubhead
Grubhead
ADMIN Andrew
ADMIN Andrew
Are you a NexxTech Electronics - Other Expert? Answer questions, earn points and help others
View Most Popular
  • NexxTech Electronics - Others
Most Popular Question
used nexxtech 175 watt power inverter
  • Electronics - Others
