20 Most Recent Whistler Power Inverter Questions & Answers
Automotive batteries are usually adequate for small inverters, (< 500 Watts). When used in a car, we suggest you run the vehicle of your engine occasionally while operating your inverter. If you use the inverter while the engine is off, you should start the engine regularly and let it run to charge the battery. Deep Cycle (marine) batteries are best for larger inverters as they are designed for several hundred charge/discharge cycles. (Automotive batteries wear out much more quickly after heavy discharge).
Whistler Power... | Answered on Jun 27, 2012
If the inverter is blowing your vehicle's lighter socket fuse, does it do it immedately or only when you try and operate a device? If its when you operate your device, it may draw more than 100-150 watts. This wattage is the limit for most lighter sockets. Double check the devices power requirement.
Whistler Power... | Answered on Dec 22, 2010
You haven't supplied enough information. An inverter only converts 12V DC to 115V AC. There are some battery packs with inverters, but that's not what you asked about. The time it "serves" is dependent on the load being connected and the battery(s) that the inverter is being supplied from. Go to a web site such as :http://www.donrowe.com/inverters/inverter_faq.html#hookup
You can learn a lot about inverters here.
Whistler Power... | Answered on Jul 13, 2010
Yes you can install 2 batteries for your systems and charged by your rv motor or exteranal charger.
Whistler Power... | Answered on Apr 22, 2010
What is the model number of the inverter? Most units the fans are thermostatically controlled and will run until the unit is cooled off.
Whistler... | Answered on Apr 18, 2016
Mkv files to play correctly require quite powerful computer. Try mpg, MPEG codes but even those when used for high definition video my require some processing power.
Electronics -... | Answered 9 hours ago
Flash memory probably corrupted, you may need to format to get it useable, you will lose data but you can try a data recovery app which should retrieve most of the data even after formatting.
Electronics -... | Answered on Nov 05, 2019
Change the region code for all DVD cd's through the supplier
Electronics -... | Answered on Nov 02, 2019
It's possible that you or someone has accidently changed the region code setting on the player.
If you type your model number and the words 'region code' into a search engine, you should find out how to reset it to your region or make it region free.
If that doesn't work there's an electrical fault on the machine.
Electronics -... | Answered on Oct 31, 2019
Tip
How to repair Motorolla Talkabout 250 antenna
I have just repaired four of these radios, with complete success.
You need a tube of black Stixall (currently £5.81 from Tool Station), a skeleton gun and a saucer of water with a good squirt of washing up liquid.
Take the back off the radio, take out the batteries and remove the rear cover by undoing the retaining screws using a screwdriver with a star shaped bit. Unscrew the circuit board now exposed using the same screwdriver bit. Remove the damaged rubber aerial with coiled copper core, being careful not to damage or distort the copper core. It lifts off one of the screw lugs revealed when removing the circuit board. Get rid of all of the old rubber.
Now put the end of the copper coil back over the lug (where it came from) and screw the PCB back on followed by the back of the unit.
Now form a new rubber cover to the copper aerial using Stixall, squirted into place. Squirt it down into the aerial housing so that it will get mechanical purchase from the body of the radio. Put on plenty, completely coating the copper aerial. Now dip your fingers in the saucer so that they don't bond to the Stixall and mold it into a smooth aerial shape. Leave it to cure for 24 hrs and then dust it with flour. Job done.
I have tested my repaired radios and they are great, the new "aerials" have lasted well. I am especially pleased that I don't have to throw them away.
Good luck - regards SJP
on Oct 16, 2019 | Electronics - Others
Plenty here;
https://ksp-electronics.com/en/product/view/5741-ta1319ap
Electronics -... | Answered on Oct 15, 2019
Error. Over Current - Peak current exceeded
Possible causes:
Motor has a short - Phase to phase or phase to ground.
Motor cable damaged/defective.
Motor cables too long.
Acceleration/deceleration ramps too short.
Damaged output phase of inverter.
EMI
Electronics -... | Answered on Oct 14, 2019
Three years is pushing the life of the batteries. Have them checked where your type of battery is sold.
Electronics -... | Answered on Oct 13, 2019
You can use Card Data Recovery. It is the professional SD card data recovery software. It can recover photos, video, audio and documents from SD card, miniSD card, micro SD card, etc. This program has two versions, one for Windows users, one for Mac users. You can visit its official website to have a look.
Card Data Recovery for Windows
Card Data Recovery for Mac
Electronics -... | Answered on Oct 11, 2019
it means you can't write new files or alter the files.
It is cs26466 ?
this has a password protection feature apparently
is it an sd card ? move the tab on the side of it
If it is a usb flash drive I do not know how you get pass the passwor dor how you enter a password when accessing it ?
Electronics -... | Answered on Sep 20, 2019
Write protect in flashdrive could mean chip problem if you cannot partition or reformat the usb drive..you can try usb low level format, partition application..be sure to back up files before doing so.
Electronics -... | Answered on Sep 19, 2019
Connect and get best solution of email related issues. Webmailhelps
Electronics -... | Answered on Aug 30, 2019
Whistler Power Inverter Logo
4 questions posted
Top Whistler Electronics - Others Experts
Marvin
Marvin
Tom Chichester
Are you a Whistler Electronics - Other Expert? Answer questions, earn points and help others
View Most Popular
  • Whistler Electronics - Others
Most Popular Question
tech question
  • Electronics - Others
