20 Most Recent
Weiser Lock ED1460X3VKD Powerbolt 1000 Electronic Deadbolt Questions & Answers
The T-turn is reversed
I my mind the actual lock bolt was assembled wrong. You need to gently twist the length adjusting unit /bolt directly out of its housing and then gentle separate the two pieces though fully separating them and then "flip" the actual little toggling metal piece that has the "U shaped and half circle looking hub that the lock shaft slides into, around from it currently position ... ie. reversing its throw. You may need to also adjust the spring metal piece underneath it as it run in a slot as well.
This worked for me ... when t-turn key is horizontal the dead bolt is extended ie. in locked position.
The deadbolt will not retract. even when new
Does the motor run when activated? If so, your friction wheel "O"ring is worn out. This is a mechanical issue and should be covered by the Lifetime Warranty.Call them. You only need to send the battery compartment side in. (inside of door)
Weiser Power deadbolt works backwards on keypad
I have installed your Powerbolt, but when I push the Lock Button, it unlocks? What should I do?First remove the cover on the inside of the Powerbolt unit. On the right hand side under the batteries, you will notice that is says "Door Direction Jumper". If the cap is mounted on Prongs 1 & 2, carefully remove it and move it over so that it mounts Prongs 2 & 3. A is right handed, B is left handed. http://www.weiserlock.com/Support/Faq/50160000000HhmZAAS.aspx
I forgot the code and I lost the key
The Weiser brand and Kwikset brand Powerbolt are identical, so these instructions will work just fine for you:
http://www.kwikset.com/Customer-Support/Product-FAQs/Faq/50160000000HhhEAAS.aspx
Have had lock for a
Here is a link to reprogramming and troubleshooting your lock. Beeping is addressed about halfway down the page:
http://www.weiserlock.com/Support/Faq/50160000000HhhZAAS.aspx
The link to Customer Service on that page will be able to get parts or further tech service.
Weiser powerbolt worked well for
Hi...
You have too be sure that the deadbolt is free when it go inside the
deadbolt hole... however this system is very low power and the (over
torque clutch) will sleep if the deadbolt it's not completely free.
Also
if you try to open the door before you unlock it, you may block the the
deadbolt inside the deadbolt hole. Take care too unlock the door before
open-it...
Good lock or good unlock
I am looking for a
powerbolt 1000
Here's a link to the Frequently Asked Questions page for the Powerbolt 1000:
The instructions for reprogramming the code can be found there. Good luck!!
Lost it and dn't know how to program it
From inside the house, remove the cover plate. Press "program", then key in the number, then press the lock button. Then, press "program" twice, then key in a second password, then press the lock button.
I have a keyless weiser deadbolt. Can't find any
Very common for the keypad to stop working.
check
that the keypad is not defective. You can disconnect the batteries and
then unplug the keypad. Now put the batteries in without the keypad
connected. If the beeping stopped, your keypad may need replacing.
You can get a replacement at the store where you bought it for free or call the Weiser support line and they will mail you one for free.
When i enter the combination you can hear the
If this is an electronic lock, you may need to replace the batteries or check that the power supply is not frazzed if it is connected to the mains.
If it's mechanical, a couple of good squirts of lubricant might get it moving.
Other than that, you might need to call a locksmith.
Regards
On my house door lock, I recharged my batterie and now the lock wont work
When it comes to rechargeable batteries there is an unspoken rule to not use them for smoke detectors, clocks, and menial electronics. Only use them for flashlights and stereo systems that you carry on your shoulder. :) All you can do is make sure that the batteries are touching all the terminals and that they are facing the right way.
