20 Most Recent
Dremel 10 Diamond Cut-Off Wheels Saw Disc Lapidary fits Questions & Answers
How do you cut a slab from rock with the dremel?
You can run a stream of liquid, (water or cutting oil) to reduce the heat, though it isn't always necessary. If you do use a liquid you'll need to be sure the cutting disc isn't to hot when you apply the liquid as the sudden temp change will cause the disc to fracture.
3/12/2010 4:29:52 PM •
Dremel 10...
Answered
on Mar 12, 2010
Grinder question
Use a pencil and straight edge to mark the cutting line on the wood. Place the wood on the saw table and line the mark up with the saw. Place the mark on the right side of the blade to ensure proper cutting. Plug the saw in and put on your safety goggles. Support the wood on the work surface with your left hand, placing it far from the saw blade. Place your right hand on the handle, and push the trigger to start the saw. Move the saw blade down onto the wood. Put constant pressure on the handle to slowly move the blade through the wood. Release the trigger and raise the blade once the cut is complete. Make diagonal cuts in the same manner, by marking the wood and lining the mark up just to the right of the saw blade. Continue as you would for a straight cut. Remove the wood from the saw. Unplug the chop saw and dust the sawdust off. Remove the dust bag from the back and empty it. Vacuum any remaining dust off of the saw.
8/27/2008 12:31:23 PM •
Dremel 10...
Answered
on Aug 27, 2008
