20 Most Recent Whirlpool Safety Bath Walk In Bathtub - Standard Without Questions & Answers
You can email me at jpintore@inbox.com and I will do my best to help you out. My name is John
Whirlpool Safety... | Answered on Dec 16, 2014
http://search.yahoo.com/search?ei=UTF-8&p=masterbath+mastershield&xa=VycGhyKg7giPCixsICzoqw--%2C1243283956&fr=b1ie7&dups=1 - LOOK into this sit and you will see it was only the retailer that folded and not the manufacturer. If you call the factory customer service they might send you a new hose free of charge. Good luck.
Whirlpool Safety... | Answered on May 24, 2009
Yes. They are every bit as safe as your standard bathtub or shower. Unlike outdoor spas or hot tubs (which are similar to swimming pools), your indoor whirlpool bathtub is emptied after each use. There are no chemicals or stored water involved.
Whirlpool Safety... | Answered on Dec 18, 2008
So this happened 6 weeks ago. If I read between the lines, I will assume that you may have just acquired this house a short time ago.
And since you are talking about an "air switch", I will assume this is an air tub.
Air tubs are designed to turn the air blower on in a pre-determined time after the water has been drained. This function blows out the remaining water in the lines and jets to reduce water accumulation and bacteria buildup.
I hope this is helpful
Whirlpool Home | Answered on Oct 12, 2019
SEEMS IT IS WORKING AS IT SHOULD . THE WATER HAS TO GO INTO THE PUMP FROM THE TUB TO BE PUMPED BACK AS JETS INSIDE .
Whirlpool Home | Answered on Jan 26, 2019
Did you turn the outer rings on the jets? They could be turned off. They are used to adjust the bubble flow, but also to turn them on or off.
Whirlpool Home | Answered on Jan 20, 2019
You have some bacteria build up on the inside of your tubing of the tub.
Try some cleaning solutions per directions on the bottle of tub cleaner made specifically for this situation.
Cleaning Solutions
US Parts Center
Whirlpool Home | Answered on Sep 23, 2018
I have galbocca jet tub which is no longer working. I live in Lawton, ok. No one works on them here. Any suggestions?
Whirlpool Home | Answered on Sep 21, 2018
Check breaker and reset switch.
Whirlpool Home | Answered on Sep 06, 2018
Whirlpool Safety Bath Walk In Bathtub - Standard Without Logo
3 questions posted
Top Whirlpool Home Experts
US Parts Center
US Parts Center
Donni Steen
Mike
Are you a Whirlpool Home Expert? Answer questions, earn points and help others
View Most Popular
Whirlpool Home
  • Whirlpool Home
Most Popular Question
need assistance maintenance
  • Home
