20 Most Recent
Kohler Bathroom Accessory Set with Classic Design, Memoirs by Questions & Answers
How to disassemble a Kholer Rite-Temp Shower
Call Kohler, most of their products have lifetime guarantees also come with diagram. Look for a set screw either beneath (underside) the handle or under a center cap on the handle. Some are obvious, others appear to be part of the design, raised outline, temp indicators etc.
Doesn't flush properly. I have removed from base but can't push
it sounds like you have something stuck in the toilet.What you need to do is try to snake then toilet.You can also remove the toilet and turn it upside down after you remove all the water in the bowl.after you turn it upside down you should be able to see if their is something stuck in the bowl.
We bought a new commode
its not normal but it happens depends on material used in constructing it. could have been worst if it was a friend or nieghbor using the bathroom, hopefully no one was hurt. so its best to just go out and get a new sturdy seat,
you may want to see if you can take the seat back to the store you got it from for an exchange. they have them in plastic or wood so make sure to pick out one that is strong and sturdy.
good luck happy holidays
How to Install Towel Ring
Place the mounting bracket against the wall and trace around the inside of the two ovals on the bracket. Gently drill a hole into the center of the traced oval. If you hit a stud, you will not need the anchor. Carefully tap the drywall anchors into the holes. Screw the bracket onto the wall, using the screws provided, into the two anchor points. Make sure the set screw is backed out far enough to set the escutcheon over the mounting bracket. Place the escutcheon over the mounting bracket, top first. Tighten the set screw with the Allen Wrench provided.
Need password for a stolen file
Okay. The question is a bit lacking in details. Password for what? Password ON what? Where was the file stolen from? Who stole the file? What is the file content. What is the file extension (the bit after the file name and the period file_name.what)?
All questions need to start 'make model (what it is)' first 3 words. And then a clear question.
For the 13 people that have tagged this 10 year old question, it is better to post your own question.
2/7/2024 6:03:08 AM •
Kohler Home
Answered
on Feb 07, 2024
