20 Most Recent
Troy Bilt Tb425cs 26cc 4 - Cycle Curved - Shaft Gas Trimmer with Ez - Start and Speed Spool Questions & Answers
Need to replace fuel lines
Hi plomelino...
Maybe this diagram will help determine which fuel line goes to what connection
Please take time to rate me
8/26/2023 7:19:15 PM •
Troy Bilt...
Answered
on Aug 26, 2023
What is the fuel line size for Troy Bilt TB525CS Trimmer?
Yes, something special to know. If the new fuel line is going into the gas tank, be sure to cut a steep angle on the end of the line going into the gas tank. This will allow enough of the line to get into the tank where you will be able to grab it thru the gas fill opening with needle nose pliers and pull it thru.
5/14/2022 4:47:09 PM •
Troy Bilt...
Answered
on May 14, 2022
TB525es attachments no longer working
NOT THE CLUTCH.. Mine started doing the same thing recently...what I found is the metal piece at the end of the main shaft that accepts the drive from the accessory was stripped out....the part from MTD/Troybilt is $60... Save the $60 its an easy fix....
Remove the sleeve at the end of main shaft.... clean thoroughly with brake cleaner...
Mix a small amount of JB Weld and fill along the walls of the "rounded out" area..Let set for about 2 hours so it gets firm but soft...
Take an attachment, and slide it up into the receiver..making sure to align them square with the receiver. this will form the JB Weld putty to the drive piece. remove the attachment immediately!!!.
Then let it set over night.... DONE works like a champ again next day.....
5/6/2015 2:46:23 AM •
Troy Bilt...
Answered
on May 06, 2015
My Troybilt TB425CS will start and run at low speeds but dies
no no no no no no no!!!
dont grind on a plug!! :D
Please get a new plug. Although there is spark - it is not enough to ignite the gas in the cylinder under load.
It is fine at idling because minimal gas is going into the cylinder.
Once under load (trigger pull) the gas/air mixture changes - and full spark is required.
Your engine is flooding because the plug is not igniting the gas.
Not only have you ground down the plug - but have also changed the spark gap.
PLEASE get a new plug, and be sure it is gapped correctly.
You did good cleaning the carb - but your problem lies in a $5.00 sparkplug.
Thanks for using FixYa !!
10/3/2013 4:31:26 PM •
Troy Bilt...
Answered
on Oct 03, 2013
My troy bilt trimmer tb20sc rope is hard to pull.
Jard you need to check that the bottom head is clean and there are no obstructions. Then check that the coil is in tight and the nuts are not loose. Finally have you been using the correct fuel mix? Clean the fly wheel with some lubricant spray and sand paper and re assemble.
9/1/2013 8:35:56 AM •
Troy Bilt...
Answered
on Sep 01, 2013
Flywheel removal from TB425CS
YOU MAY HAVE TO USE A PULLER FOR THE FLYWHEEL I CAN'T SEE ANYTHING ON THE BREAKDOWN OF THE ENGINE THAT WOULD SHOW ANY THREADED HOLES FOR BOLTS TO REMOVE THE FLYWHEEL
8/18/2013 11:02:32 PM •
Troy Bilt...
Answered
on Aug 18, 2013
