20 Most Recent Black & Decker Black and Decker & Grass Hog Electric Trimmer Questions & Answers
0answers
When on edger spool feeds all the time. The roll only lasts about a
you either have the spool wound wrong or loose also could be a bad feed head
6/18/2015 11:14:21 PM • Black & Decker... • Answered on Jun 18, 2015
My black and decker grass hog wont last about 5 minutes and the line empty?
Have you tried re assembley? take it apart and completely redo the whole line reel. i f this does not work. Contact Black and Decker online.
6/14/2015 7:25:20 PM • Black & Decker... • Answered on Jun 14, 2015
0answers
Why won't the spool on my B&D weedwacker rotate?
Is it on the right way? Does it face the correct way? Is it clogged with solid grass?
12/15/2014 6:43:38 AM • Black & Decker... • Answered on Dec 15, 2014
My replacement spool won't lock in and keeps releasing string 36volt 13" B&D trimmer
Ensure you are winding the line in the correct direction
10/25/2014 9:31:04 PM • Black & Decker... • Answered on Oct 25, 2014
My black and decker edger cannot start
Ok, the first thing I check is the exhaust hole in the unit. Spiders and wasps like to build their nest inside the muffler hole. I have had this happen many times. Then you should replace the spark plug every year, as they will corrode when sitting and will not spark when under compression. The next step is to check to see if it is getting fuel. Is the plug wet, pull it out and check it, then check to see that the plug is getting spark, by inserting Phillips head screwdriver into plug wire and hold 1/2 inch from cylinder head and pull the rope. There should be a blue spark. Also if the gas has been in it for a while drain out old gas. ( This should be done at the end of season each year to prevent gelling in carburetor). Then replace with fresh oil and gas mixed with Sta-bil, this is a brand name gel dispersant and stabilizer. This is available at most parts stores. Now pump the bubble to fill carb. with fuel Make sure there are no leaks in the fuel line going to and from the bubble pump. If there is replace the line and or bubble pump. Now try to start the unit. Good luck, if you have no spark get back to me and I can walk you through the steps to diagnose no spark condition.
8/29/2014 3:38:56 PM • Black & Decker... • Answered on Aug 29, 2014
0answers
Instructions for replacing electric switch?
The switches probably have to be bought from B & D. Look up their web site with the model number and ask what the switch will cost. They are a real bugger to take apart. You have to be really careful since everything is so compact.
8/19/2014 5:16:48 PM • Black & Decker... • Answered on Aug 19, 2014
Black & Decker Black and Decker & Grass Hog Electric Trimmer  Logo
148 questions posted
Top Black & Decker Garden Experts
Thomas Perkins
Thomas Perkins
Mike Cairns
Mike Cairns
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
View Most Popular
  • Black & Decker Garden
Most Popular Question
replace string in grasshog xp electric
  • Garden
