20 Most Recent LG LRBN22514ST Bottom Freezer Refrigerator Questions & Answers
My lg lrbn22514st if i dont open the door within a
It is call vacation mode, the machine is operating normally.
1/1/2018 11:09:28 AM • LG LRBN22514ST... • Answered on Jan 01, 2018
Growling noise coming from back of fridge
Try lubricating all fan bearings that you can get to. Make sure fan blades not hitting any thing.
8/27/2017 2:48:04 PM • LG LRBN22514ST... • Answered on Aug 27, 2017
The unit stopped running. No lights inside either.
With all you tried well; you may need a technician.
7/12/2015 4:29:10 PM • LG LRBN22514ST... • Answered on Jul 12, 2015
2answers
Ice in the bottom of the freezer
Check the door gasket for a leak. Air entering past the gasket will form ice.
2/13/2015 2:02:20 PM • LG LRBN22514ST... • Answered on Feb 13, 2015
Have a LG M# : lfd22860st with a "DH" code, and I believe that for the defrost heater/cycle. My question is I ohmed out the heater and defrost bi-metal, so is the main PCB board the only thing else i
Hi Dan, you can do a forced defrost on this unit.the main control board has a little black button that if pressed twice will activate the forced defrost. It will only defrost for 5 min and only if the defrost thermostat and fuse are closed. Hope this helps.
11/24/2013 3:09:17 AM • LG LRBN22514ST... • Answered on Nov 24, 2013
0answers
Lg fridge freezer not staying cold
About the icons: The beer is tip link, if a tech saves ya some money buy em a 6 pack. The small green square=personal message. The green dot is a link to my web page on appliance repair and other general BS I love to post. The letter sends me email.I love fan letters! LOL
7/22/2012 5:22:33 PM • LG LRBN22514ST... • Answered on Jul 22, 2012
Ice in the freezer isn't frozen real
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
First I would check cold control. Thats where you turn it off, if your temp is not warm. it can
be defective and not shutting off. If your temp is warm proceed with the following.
I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if FREEZER CONTROL is turned WARMER WHICH MAKES THE REF COLDER AND VICE-VERSA. SEE?
The ref. temp should be about 33-35
The Freezer temp should be 0 to 10 Any thing below these temps is overkill and a waste of elect
The higher the number you turn it up to is the coldest
But is probably a common defrost problem The ice build up
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
Make sure back cover is on the fridge. Some take them off and throw them away.
make one out of cardboard if its gone, using the holes of the old one.
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If
you need more help go here:
http://www.applianceaid.com/procedures.html
MORE
TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
9/6/2011 4:50:40 PM • LG LRBN22514ST... • Answered on Sep 06, 2011
My freezer won't freeze but the fridge works.
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
8/7/2011 12:27:20 PM • LG LRBN22514ST... • Answered on Aug 07, 2011
Water leaking in at the bottom of the freezer and
Sometimes a solid ground wire
wrap around the defrost heater and the other end stuck in drain hole has helped for me. Avoid letting the wire or whatever to touch the plastic side of the hole.
8/1/2011 3:08:24 PM • LG LRBN22514ST... • Answered on Aug 01, 2011
Frizey is right but cool r not found
please tell me what you are trying to say, and i will help you.
3/16/2011 7:02:23 PM • LG LRBN22514ST... • Answered on Mar 16, 2011
The evaporator coil will not defrost and the led
you have a bad defrost control. your refrigerator is probably in warranty call the number in the owners manual.
12/17/2010 12:29:13 AM • LG LRBN22514ST... • Answered on Dec 17, 2010
Need fresh parts of my LG fridge GL-T242QM. Two
That is not that hard to fix and you can easily buy the parts yourself online...
Here is a tip that will help you with the online buying...
How to Buy
Appliance Parts Online
heatman101
12/16/2010 4:46:56 AM • LG LRBN22514ST... • Answered on Dec 16, 2010
The ejector or auger broke
Hi!!
Click on the following link to identify and order your IceMaker broken part http://www.repairclinic.com/PartDetail/Ice-Maker-Component/1303199?modelNumber=LRBN22514ST
A - 4 THUMBS - rating is appreciated for answering your FREE question. Thank you for using FixYa
10/7/2010 11:14:45 PM • LG LRBN22514ST... • Answered on Oct 07, 2010
LG LRBN22514ST Bottom Freezer Refrigerator Logo
45 questions posted
Top LG Refrigerators Experts
ZJ Limited
ZJ Limited
Jay Finke
Jay Finke
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
LG Refrigerators
  • LG Refrigerators
Most Popular Question
refrigerator freezer not cooling
  • Refrigerators
