20 Most Recent
Ingersoll Rand 2545/7100 Electric Air Compressor Start Up Kit 32305898 Questions & Answers
I have an Ingersoll Rand 2545 Electric Air
I don't know if your unit is exposed to the direct sun light if it is I suggest you create some shade , or if this this unit is enclosed is not getting enough air flow to keep cool.
( this air flow helps to stabilized the sensor that stop and start the compressor )
How to change oil
should have a square headed bolt on bottom or underneatrh to drain replace and refill to proper level
Electric Air compressor just hums then trips breaker.
usally there is a releaf valve that takes the pressure off the compressor while it is resting. If that pressure is not off when the drive piston starts the motor will overload and blow the the breaker or reset. Check for a releaf valve for when the unit has reached full pressure
Compessor cycles on and off
Have you checked for any air leaks on all the pipes and hoses on the compressor ? Air leaks are the most common cause of continuous cycling.
Do not compressed air
without knowing the full problem I am thinking that you have no air flow. First check the oil level then check the regulator adjustment to make sure it is not turned all the way down
How to reasseble the open compressor model esv 7*5
Not what you want to hear, I'm sure, but I'd recommend contacting your local Ingersoll-Rand distributor. These double acting, water cooled machines require substantial expertise.
A unit of this size (probably 20-25HP or so) is probably going to cost more to rebuild than a new screw compressor costs. However, they can be very efficient machines.
Air dryer. Why is new compressor running hot?
There are several reasons for a compressor to run too hot, including high compression ratio, high return gas temperatures, and lack of external cooling. High compression ratios are the result of either lower than normal suction pressures or higher than normal discharge pressures.
