20 Most Recent LG LRSC26980 Refrigerator Questions & Answers
0answers
2answers
After a power outage my LG electrocool not longer gets cold nor does the freezer work
It looks like you have had a surge through the refridgeration system, this would mean you have to replace the motor but that woul cost more than the fridge itself
1/21/2016 1:09:25 PM • LG LRSC26980... • Answered on Jan 21, 2016
2answers
Ice maker only produces 30 cubes per day (24 hrs) since new.
You probably need more water pressure going to the frig. check that first.!!
5/14/2014 1:01:23 PM • LG LRSC26980... • Answered on May 14, 2014
Water running down beside ice maker
is the water over pouring into the ice cube trays? Some fridges have a adjustment option where you can choose how much water the fridge puts into the tray - modify this setting if you have it, or contact lg for a repair.
1/14/2014 7:52:49 AM • LG LRSC26980... • Answered on Jan 14, 2014
5answers
Ice tray sometimes stuck when dumping off ice
I had the same problem. I did the following and it now works great. The ice tray has a square tab on the rear leftside. As the tray rotates to dump the ice, the tab runs on a curved section of the the ice maker frame. The curved section becomes rough with use and causes the tray to stick when it is returning to the fill position. I carefully sanded the curved section of the frame to smooth it out. No problems since.
One does have to dismantle the ice maker to effect this repair.
7/5/2013 3:05:51 PM • LG LRSC26980... • Answered on Jul 05, 2013
5answers
LG REfrigerator - water line connector
Try closing the water valve slightly to reduce the water pressure to the unit.
Sgt 48
5/29/2013 5:31:51 PM • LG LRSC26980... • Answered on May 29, 2013
Whirlpool icemaker dripping water
Fit he ice maker is dripping water, then you have a problem with the "water valve" solenoid not closing completely. Here is the valve to order.The part comes with a 365 day, any part, any reason return policy.
11/9/2012 11:16:44 PM • LG LRSC26980... • Answered on Nov 09, 2012
I keep getting pinhole leaks
where is it breaking at the fitting
9/22/2011 9:35:02 PM • LG LRSC26980... • Answered on Sep 22, 2011
LG Model LFC23760
What type of filter should be installed on a LG model LFC23760 refrigerator?
7/20/2011 2:11:38 PM • LG LRSC26980... • Answered on Jul 20, 2011
My refrigerator keeps beeping as if I left a door
http://us.lge.com/download/product/file/1000000180/LRSC26980owners.pdf
I looked and looked in the manuals and the only thing that I found for dispensor and button was the lock and unlock of the dispensor - if you hold the lock button down for 3 secs it will either lock or unlock the buttons. So you need to check to see whether the controls are locked or not. If they are then unlock and set the temperature for the refrigerator and freezer on your control panel.
http://www.ajmadison.com/ajmadison/itemdocs/8645A_Eng.pdf
I don't understand why your food is thawing unless there was a power surge that changed all your settings.
If this isn't the problem, let me know and I will look further. Troubleshooting a problem without being able to see what the indications are, is something that takes a lot of trial and error.
6/10/2011 9:02:20 PM • LG LRSC26980... • Answered on Jun 10, 2011
LG Refrigerator GR2211GDC. Compressor was
Whoever replaced the compressor obviously left a leaking solder joint. That needs to be fixed, after which the unit needs to be recharged.
5/26/2011 3:04:28 AM • LG LRSC26980... • Answered on May 26, 2011
How do you rmove the televison from the right-hand
You should move all funiture to the wall.You should move all subjects to walls. You should put more fragile things on that place where you will not bear the TV. If at you have the big TV that move it in parts or employ workers
2/15/2011 2:18:56 PM • LG LRSC26980... • Answered on Feb 15, 2011
Can the plastic water lines be replaced with
yes, you can
1/11/2011 7:40:49 AM • LG LRSC26980... • Answered on Jan 11, 2011
Display panel on lg fridge has err message
look up error message? is there something besides "err" displayed? err FF= freezer fan.. what does your owners manual say? or the web site?
12/26/2010 11:41:00 PM • LG LRSC26980... • Answered on Dec 26, 2010
LG LRSC26980 Refrigerator Logo
61 questions posted
Top LG Refrigerators Experts
ZJ Limited
ZJ Limited
Jay Finke
Jay Finke
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
LG Refrigerators
  • LG Refrigerators
Most Popular Question
water running down beside ice maker
  • Refrigerators
