20 Most Recent Dewalt "Heavy Duty 1/2" Impact Wrench Questions & Answers
If it ain't broke don't fix it. I'd make sure nothing inside isn't rusting just to be sure.
Dewalt "Heavy... | Answered on Jan 17, 2014
Its newmatic right just put a few drops oil right down the air feed and a moisture trap inline off the compresser would be goodHowever the picture looks like its electric and you don't realy have to do that now its prelubed and shouldn't be an issue for many hours of service. If it is air then wd 40 works fine the problem comes in when they sit with out use for long peirods of time they rust and seize and thats hard to fix
Dewalt "Heavy... | Answered on Dec 29, 2010
Try this link:
https://www.ereplacementparts.com/dewalt-dw423-type-inch-evs-random-orbit-sander-parts-c-1009_2742_2758.html
Dewalt Tools &... | Answered on Apr 02, 2019
no, but there may be an overload fuse. My guess is that it is part 62 here, but not available. Take it to a DeWalt service centre
https://www.ereplacementparts.com/dewalt-dw431-type-electric-belt-sander-parts-c-1009_2742_2764.html
It is available here, but is $88. Lot of money to lay out on a guess, which is all the more reason to get it looked at professionally. It may also be the motor windings burned out.
https://www.toolpartsdirect.com/dewalt-dw431-type-5-electric-belt-sander.html
Dewalt Tools &... | Answered on Feb 27, 2019
Either the blades are incorrectly installed causing the head to jam or the safety cover is not installed properly - there is a safety mechanism that locks the cutter head when the cover is removed.
Dewalt Tools &... | Answered on Feb 02, 2019
Typical cause is low voltage - but can also be a bent driver or something jammed in the nail track.
Is this a finish nailer or framing nailer?
That symptom usually indicates a low voltage issue - not sure how the adapter may affect this, I've never run them with a 20v battery.
Try it with a standard 18v and see if you have the same issue - please comment back with the results, I'm curious.
This is a common problem with this compressor and still is a problem in 2014.It is under powered and trips the reset
Dewalt Tools &... | Answered on Feb 01, 2019
copy and paste in search engine. took about 5 seconds to find answer.
Dewalt Air Compressor D55146 Belt Replacement
Dewalt Tools &... | Answered on Nov 23, 2018
Without inspecting tool, it would be hard to definitely tell what part, I would call Dewalt, they will be glad to help you. You do not want to throw parts at it.
1-800-433-9258
Dewalt Tools &... | Answered on Nov 20, 2018
either not properly closed or latch damaged
Dewalt Tools &... | Answered on Jul 10, 2018
Dewalt "Heavy Duty 1/2" Impact Wrench Logo
2 questions posted
Top Dewalt Tools & Hardware - Others Experts
John Trevino
Ruben Bustamante
john h
Are you a Dewalt Tool and Hardware - Other Expert? Answer questions, earn points and help others
View Most Popular
  • Dewalt Tools & Hardware - Others
Most Popular Question
exposed water seems
  • Tools & Hardware - Others
