20 Most Recent
Elite Home Electronic Personal Bathroom Scale Clear Questions & Answers
Need to know how to adjust the weight
Try putting brand new batteries in and letting the scale zero out and then shut off on its own. Sometimes it's "zero" is misrepresented by an old set of batteries. Also, do any kids live in the house that might have jumped on it? If so, it would be wise to buy a new one as the sensitivity will be ruined for life.
How do I set the
On the display, hit "set" for 3 seconds. The hour setting will blink. Press the up or down arrow to increase or decrease the hour number. Press "set" again. The minute setting will blink. Press the up or down arrow to increase or decrease the minutes. Press "set" when finished.
Can i change the program speed on my elite hd power chair myself
Probably not. You need a programmer (a PP1) that will allow you to increase the factory speed. But it's probably set at 100% already. Other than setting the speed on the joystick to full and changing the programmed speed will you be able to get the chair 's speed increased.
How do i change the program speed on my elite hd power chair
You need a programmer (a PP1) that will allow uo to increase the factory speed. But it's probably set at 100% already. Other than setting the speed on the joystick to full and changing the programmed speed will you be able to get the chair 's speed increased
Go go elite traveler has a continuous beeeeeeep.
hi, so when you first turn it on, bleep bleep ? if so check the four connections on the rear axle and frame partvwhere it comes apart
mostlb likely a bad connection there with one of pins or sockets.
regards
gewizrepairs.co.uk
