20 Most Recent Solo Backpack Sprayer 3 Gallon Capacity, Model# 473ecs Questions & Answers
I have a 3 gal. back sprayer. When you try to
Hi there
There are many possible reasons for your sprayer not pressurizing. If the pump lever is moving freely and does not seem to be building pressure while pumping it is possible that the O-ring at the valve is damaged, the seal in the pressure regulator is leaking, the piston or the collar is worn. Any of these problems will require disassembly of the unit and inspection of each part. If you do feel resistance building as you pump but quickly loose pressure you likely have leaks in the diaphram, it's seal, the pressure cylinder or the tank itself.
If you are comfortable disassembling the unit and inspecting the parts for wear or damage most of the individual replacement parts are fairly easy to replace and readily available online from Solo or at many retail outlets and supply companies. Solo has done a great job with how-to videos and instructions for each procedure on their web site www.solousa.com
If you are not comfortable disassembling and repairing your sprayer yourself you can try contacting a mower/equipment repair shop in the Redding area as is seems the nearest Authorized Solo sprayer repair center is Cloverdale Saw in Cloverdale CA, 707-894-2273
12/31/2010 3:09:09 PM • Solo Backpack... • Answered on Dec 31, 2010
I have an Alko solo ride on. The whistle that goes off when the collector is full is stuck on. I have cleaned out the cutting deck and can't see any grass underneath. Any suggestions?
Try checking the sensor that activates the whistle. If it's dirty or clogged with grass or debris, clean it. If the problem persists, try resetting the control panel or consult the manufacturer's manual for further troubleshooting steps. If the issue can't be resolved, it may be necessary to have it serviced by a professional.
2/5/2023 5:56:50 PM • Solo Garden • Answered on Feb 05, 2023
Where can you get the parts for SOLO blower model 445
fastest easiest do an online search may find a place in your area
1/15/2022 12:24:40 AM • Solo Garden • Answered on Jan 15, 2022
Engine is leaking chemicals from tank of solo 450 mist blower
If leaking around the seal try replacing the gasket. If leaking through a hole then may have to change the tank. Sorry without pics hard to be certain.
5/4/2019 2:04:06 AM • Solo Garden • Answered on May 04, 2019
Where do I purchase an Ign. coil for a Solo Model 445 backpack blower?
Only from the manufacturer.
12/2/2017 10:58:18 PM • Solo Garden • Answered on Dec 02, 2017
Can anyone point me to a instruction manual for a solo 606 chainsaw?
http://www.acresinternet.com/cscc.nsf/ed1d619968136da688256af40002b8f7/1f4385973568a2aa88256b5e00150a08?OpenDocument
2/19/2015 3:45:56 PM • Solo Garden • Answered on Feb 19, 2015
Why is my chain saw leaking oil out the side when runnng
bar not tight or wrong type of oil
9/7/2014 3:00:41 AM • Solo Garden • Answered on Sep 07, 2014
Why will my solo leaf blower not start ?
Possible reasons for not starting.. No Fuel Spark plug dirty or worn out Ignition cable weak Ignition starter faulty Starter cable stuck part way Carburetor dirty or fuel mix setting in adequate Choke not set correctly
8/7/2014 12:57:00 PM • Solo Garden • Answered on Aug 07, 2014
0answers
Solo Backpack Sprayer 3 Gallon Capacity, Model# 473ecs Logo
1 questions posted
Top Solo Garden Experts
john h
ADMIN Andrew
ADMIN Andrew
CJ Rock
CJ Rock
Are you a Solo Garden Expert? Answer questions, earn points and help others
View Most Popular
Solo Garden
  • Solo Garden
Most Popular Question
3 gal back sprayer when try
  • Garden
