20 Most Recent Pentair MINIMAX NT TSI IGNITER Questions & Answers
Pentair minimax nt e04 code
It is nice calendar update clash of clans
12/7/2017 11:45:59 AM • Pentair MINIMAX... • Answered on Dec 07, 2017
Minimax NT 400 TSI Heater problem
I bet that your 15 seconds of flame are more like 7 seconds. The time is very important. If the flame is not recognized after a specific time the valve is shut off. If the flame sensor is GOING bad but still make some rectification then you may get the issue you are having. I would start with the flame sensor and work from there.
5/5/2017 10:44:49 AM • Pentair MINIMAX... • Answered on May 05, 2017
2answers
The Digital Panel on the front of my Pentair
TIME TO CLEAN THE FILTER
5/25/2015 9:36:36 PM • Pentair MINIMAX... • Answered on May 25, 2015
Heat pump is reading LP
LP means low refirgerant pressure have it checked then if pressures are okay its a bad sensor Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/kevin_7b506228149c3829
11/9/2014 1:33:17 AM • Pentair MINIMAX... • Answered on Nov 09, 2014
I get an EO5 code (3 red blinks) on the Pentair model 4300 TSI. I changed the ignighter but still the code is the same. There is no fire to the burners?
If your gas is on, and the ignitor is good, and your sure there are no wire shorts, the only other options are the gas valve or the flame rectifier. I would put my money on the flame rectifier. It is located right next to the ignitor, and is very inexpensive to replace.
4/16/2012 5:52:18 PM • Pentair MINIMAX... • Answered on Apr 16, 2012
I have a minimax ch
Check your SENSOR. With the Minimax ch heater, you might be using an 'IntelliTouch' panel that controls your equipment. If you are, check the reading that the panel says the water temperature is and then check the temperature of the water 'coming out' (spa??) manually with a floating thermometer. When the heater cycles off, check the difference between the 2 numbers. Say the panel says 102 & the thermometer says 95?? - that is a faulty sensor, telling the heater that the water has reached 102, so it cycles off before ever getting hot. If you're not using the IntelliTouch, you will be checking the display panel on the actual heater itself & again the floating thermometer. Now... if the temperature is less than a 4 degree difference you can always calibrate/or have calibrated the heater.
8/4/2010 8:50:46 PM • Pentair MINIMAX... • Answered on Aug 04, 2010
2answers
I have a Purex Triton MiniMax 400 that is cycling
i have the same problem and i jumped the two red wires to bypass the thermal switch
6/1/2010 1:58:22 AM • Pentair MINIMAX... • Answered on Jun 01, 2010
My minmax is powered on, heat vent is blowing hot,
What size is the heater and how many gallons is the pool? is the pool covered? How long is the heater being allowed to run?
4/14/2010 3:51:34 AM • Pentair MINIMAX... • Answered on Apr 14, 2010
We went in the spa the other night I turned on the
the thermostat is most likely the problem
4/9/2010 4:51:01 PM • Pentair MINIMAX... • Answered on Apr 09, 2010
The temperature on digital readout says a certain
Your temp sensor has gone bad. This is a small tube with wires coming from it. You will find this on the left side of the water manifold. Follow the wires to the front of the heater and unplug it from the temp board. Install the new one in the reverse fation. good luck.
3/19/2010 1:45:57 AM • Pentair MINIMAX... • Answered on Mar 19, 2010
I do not know if there is a pilot light in this
This model has a hot surface ignitor. If rain water got inside the unit while fireing the ignitor would fail. It is located on the center of the firewall just above the burners. be sure to shut the power off then the ignitor can be removed and the new one installed. This is a very frail part so be careful with it.
1/27/2010 9:31:27 AM • Pentair MINIMAX... • Answered on Jan 27, 2010
Looking for owners manuel for a minimax n7 the heat wont turn on
This will get you to their site www.pentairpools.com
You will find many things there just brouse through till you find your heater. Good luck.
1/22/2010 1:20:43 PM • Pentair MINIMAX... • Answered on Jan 22, 2010
Pentair MINIMAX NT TSI IGNITER Logo
50 questions posted
Top Pentair Pool & Spa Experts
Jay Finke
Jay Finke
ZJ Limited
ZJ Limited
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
View Most Popular
Pentair Pool & Spa
  • Pentair Pool & Spa
Most Popular Question
purex triton minimax 400 cycling
  • Pool & Spa
