20 Most Recent LG LRM1230W Microwave Oven Questions & Answers
check the elements on top of inside the mwave
LG LRM1230W... | Answered on Sep 27, 2018
I am not an expert on Miocrowave ovens, but from past experience I know that they have a number of micro-switches on the door as safety devices. If these switches are faulty, the last safety feature is to short the supply and blow the fuse to stop the microwave from operating in an unsafe condition. Obviously the switches would have to be checked first before jumping to any conclusions and a number of other faults would probably cause the fuse to blow as well.
LG LRM1230W... | Answered on May 09, 2016
The screen in the door prevents microwaves from being emitted through the window, so don't remove it. If you feel it is faulty, take it to a service tech, as the door must be in good condition.
LG LRM1230W... | Answered on Aug 31, 2013
http://service.us.panasonic.com/OPERMANPDF/NNC988B.PDF
hello , here is the manual for that model nn-988w / nn988b , thanks for voting FIX YA !
LG LRM1230W... | Answered on May 26, 2013
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Basic Microwave Oven TroubleshootingTips
heatman101[p]][p
LG LRM1230W... | Answered on Feb 11, 2013
Mine did this too. Also, at times when I would shut the door, the whole keypad would go dark and the clock would have to be reset. There were also times when I would push Start and it would do nothing. I'd have to unplug it so it would reset itself.
I used a screwdriver and forced the door open. Mine is about 2 years old and it's now dead. Biggest piece of junk I've purchased in years. Really ticked me off, no more LG products for me. I had a Toshiba that lasted me 22 years and the only thing that went bad on it was the light stopped working and the fan cover fell off.
LG LRM1230W... | Answered on May 15, 2012
This indicates the magnetron has failed, "heart of the microwave oven" if everything else is working then the culprit is as stated above, often gives off a strong odor. In most cases it is cheaper to replace the oven rather than repair.
LG LRM1230W... | Answered on Mar 02, 2012
Hello, I usually get parts from a company called SERVALL. They have a Website,(SERVALL .com). They have been in business since 1929 and have Franchises so look in your local phonebook for nearby stores too! Before attempting to piecemeal repair you may want to see if the Manufactuer has replacement parts for this.
Sears has some easy-outs for broken bolts, some are for small sizes. If this shaft is permanently mounted in the case of your Microwave, the shaft may be part of the motor or embedded as a drivegear box. Unfortunately, when you drilled into the shaft you also pressed it into the collar.
You can try to Browser search by using the appliance name and model and add, illustrated, diagrams, shop manual, and so on for variations until you get a hit. It may be difficult to find the diagrams because people usually do not fix these themselves.
I hope my solutions include something very helpful and good-luck with this repair.
LG LRM1230W... | Answered on May 28, 2011
Microwave Oven Basic Troubleshooting Tips
heatman101
LG LRM1230W... | Answered on May 14, 2011
heatman101';';';l;
LG LRM1230W... | Answered on Mar 27, 2011
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic Microwave Oven Troubleshooting Tips
heatman101
LG LRM1230W... | Answered on Feb 25, 2011
Yes! If you smelled a very strong odor in the microwave oven when you open the door, it is the magnetron.
LG LRM1230W... | Answered on Jan 13, 2011
A loud buzz, hum, or groan is usually a
shorted high voltage rectifier diode, but a sound like gurgling into an
empty coffee mug is one symptom of a failed magnetron, and yet the mag can
be bad without that sound.
Here are some links you
or someone you know can use (in order given) for test help, but read
the safety warnings first:
http://www.microtechfactoryservice.com/xformer.html
http://www.microtechfactoryservice.com/cap_test.html
http://www.microtechfactoryservice.com/diode.html
(if it is NOT shorted or burned looking,
it\'s probably fine)
http://www.microtechfactoryservice.com/mag_test.html
(continuity can be good even
though mag is bad!)
You can order
parts for this brand from
Encompass here or you can call them toll-free at 866-779-5835.
We\'re happy to help you with free advice and we\'d appreciate your
thoughtful rating of our answer.
LG LRM1230W... | Answered on Aug 22, 2010
http://www.fixya.com/support/r5508031-microwave_oven_basic_troubleshooting
heatman101
LG LRM1230W... | Answered on Aug 07, 2010
In all likelihood the mangnetron has failed, or perhaps even the Power Supply. or a fault that is shutting the system down for safety reasons You need to have it serviced by a reputable service centre/man. Ensure you get a firm "Quote" before proceeding, and remember these days the cost of repair can equal or exceed the price of a new one.
LG LRM1230W... | Answered on May 02, 2010
LG LRM1230W Microwave Oven Logo
36 questions posted
Top LG Microwave Ovens Experts
William Miller
William Miller
Steve Allison
Steve Allison
Jerry Greenberg
Jerry Greenberg
Are you a LG Microwave Oven Expert? Answer questions, earn points and help others
View Most Popular
LG Microwave Ovens
  • LG Microwave Ovens
Most Popular Question
runs but not heat
  • Microwave Ovens
