20 Most Recent
LG LMV1314 Microwave Oven Questions & Answers
WHY DID MY MICROWAVE OVEN
Actually you don't need to replace the microwave, you just need to replace the carboard piece or "wave guide" and replace the magnetron inside the microwave behind the cardboard piece. The magnetron will commonly arc out to the wave guide if the wave guide gets something that splatters on it. The repair isn't cheap because the magnetron costs about $200 and the wave guide is another $30 or so, but if you replace both these parts you should be good to go again.
The magnetron usually have 5 years warranty, however you need to speak with manufacturer itself for the same.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Wont heat
Hi, there are three issues that will cause a no heat situation in a microwave. these issue are a failed Magnetron, busted cut-off fuse and, failed diode.
I recommend checking all these area that are located inside the microwave for faults.
The most common issue will be a failed Magnetron.
The diode and, fuse will be located on the noise filter assembly.
Burnt package of vegetables in my microwave
You will need your full model number from the tag on the unit.
You can order parts from Encompass (formerly Tritronics). Or you can call them toll-free at 866-779-5835.We're
happy to help you with free advice and we'd appreciate your
thoughtful rating of our answer.
My new LG solardome MA3884vc overheats melamine plate @30 seconds
If your LG Solardome microwave oven is overheating a melamine plate within 30 seconds, there could be a few potential issues at play:
- Power Settings: Check to see if the power settings on your microwave are too high. If it's set to a high power level, it can cause certain materials, like melamine, to overheat quickly. Try reducing the power level and see if that helps.
- Plate Material: Melamine plates are not suitable for use in microwave ovens as they can overheat and potentially release harmful chemicals into your food. It's recommended to use microwave-safe dishes made of glass, ceramic, or microwave-safe plastic.
- Microwave Performance: If the microwave is consistently overheating items within such a short time frame, it might indicate a malfunction. In this case, it's best to contact LG customer support or a certified technician to inspect and repair the microwave.
- Placement and Usage: Ensure that the plate is placed centrally on the turntable and not touching the sides of the microwave. Also, avoid using the microwave for extended periods without interruption, as this can cause overheating.
- Testing with Different Materials: Try using a microwave-safe ceramic or glass plate to see if the issue persists. If other materials heat up quickly as well, it could indicate a problem with the microwave itself.
How to remove door COVER from door of LG Microwave model LMHM2017ST
Here are the steps to remove the door cover from the door of your LG Microwave model LMHM2017ST:
- Unplug the microwave from the power source.
- Open the microwave door and locate the four screws on the inner edge of the door.
- Use a Phillips screwdriver to remove the four screws.
- Carefully separate the outer door panel from the inner door panel.
- You will now see the door cover attached to the outer door panel.
- Use a flathead screwdriver or plastic pry tool to gently pry the door cover off of the outer door panel. Start at one corner and work your way around the edge.
- Once the door cover is removed, you can replace it with the brushed silver cover from the new door.
- To reassemble the door, simply snap the new cover onto the outer door panel and then reattach the outer door panel to the inner door panel using the four screws you removed earlier.
Make sure to be careful when removing the door cover, as it can be fragile and may break if handled roughly.
LG microwave door open pad broke.
Question edited for clarity.
Question moved from Building Materials to LG Microwave.
Take into an LG Service centre for repair. They are sealed by security screws and are dangerous inside. You won't be able to get parts.. If it is a counter top microwave and cost $60, just buy a new one as they are a disposable item.
