20 Most Recent
Worx 16" Electric Lawn Mower Questions & Answers
Won't start
You may have a switch problem in the handle or the little voltage box may be burnt out. That'll be a little feature creature about 1 inch square and one corner is angled and it has four little legs on it, One of those legs is opposite to the other three. You may have to replace that. But make sure you have 120 volts going to the motor before you purchase anything. Be very careful how you remove the wires from that little box. Mark them with a little drawing if you have to and make sure you put the proper colors back where you took them from. Good luck
10/9/2009 8:44:04 PM •
Worx 16"...
Answered
on Oct 09, 2009
How to remove broken bit in a WORX 176L
pull locking sleeve back as shown on page 3 of instructions. pick up a can of PB blaster dry lube spray can at HD and spray some around bir.
https://www.manua.ls/worx/wx176l/manual?p=3
12/1/2023 12:23:30 AM •
Worx Garden
Answered
on Dec 01, 2023
My spool holder on my worx edger/ trimmer keeps unscrewing itself
ck out this video...https://www.google.com/search?q=spool+holder+on++worx+edger/+trimmer+keeps+unscrewing+itself&newwindow=1&sxsrf=APwXEdfauQkwFmaCtC3ubVCJYTpRDnvb2Q:1687901890446&source=lnms&sa=X&ved=2ahUKEwj70uHEtOT_AhXEg4kEHYYZAUQQ0pQJegQIDxAC&biw=1280&bih=567&dpr=1.5#kpvalbx=_NVebZNnDOImgptQP9a-08Ao_9woops..my bad. you'll have to copy and paste the link. ):
6/27/2023 9:42:40 PM •
Worx Garden
Answered
on Jun 27, 2023
Was using my 110volt worx
Your trigger might have gone bad. Take your handle apart,and check to see if you have power to the switch,you can use a jumper wire to bypass the switch to see if it starts.
6/5/2023 8:38:32 PM •
Worx Garden
Answered
on Jun 05, 2023
