20 Most Recent Sta Rite 1 Hp Above Ground Pump Ne641 Questions & Answers
Better replace the switches one is shorted out and will cause a fire, best to replace both and check wire connewity for bad wireing.
Sta Rite 1 Hp... | Answered on Oct 26, 2013
is there a reset switch to press..?
Sta Rite 1 Hp... | Answered on Jun 09, 2011
The FLA (Full Load Amps) for a 1 HP single phase motor is 16 amps at 115 volts. 5% is the maximum allowable volt drop from the main electric panel to the pump per NEC (National Electric Code). When these values are plugged into the volt drop formula, such as this one:
http://www.nooutage.com/vdrop.htm
90 feet is the maximum allowable distance for a #12 copper rated at 75 degrees C.
Sta Rite 1 Hp... | Answered on May 03, 2011
sta-rite pump is humming and no water
Sta Rite 1 Hp... | Answered on Mar 21, 2011
Hi Tom, The reason your pump is getting noisy is because the motor bearings are worn out. This can also be caused if the shaft seal between the motor and the wet end is leaking. The bearings can't be lubricated because they are sealed. The best solution is to have the bearings replaced as well as a complete seal kit for the wet end.
Sta Rite 1 Hp... | Answered on Oct 17, 2010
It sounds like your pool pump is either not primed or is not strong enough to provide adequate suction. Check to make sure the pump is properly primed. Check for cracks in the lines that might also cause loss of pressure in pool pumps.
Sta Rite 1 Hp... | Answered on Sep 29, 2010
Try consulting the owners manual for these pool pumps. You can find one online. That should give you a diagram with detailed and numbered parts to help you figure out where your seals are and how to get to them.
If this is between two screws when your looking at the front of the pump then it is in the suction gasket between the pump pot and the pump housing and the one you have could be a paper gasket and should be replaced with a rubber or cork one this can be done by removeing all four screws and gently pulling the two pices away from each other and clearing the old one out and putting the new one in. That is the hard part as there will be a extention comeing from the pump into the pot and is about two inches long you need to clear this with the new gasket and then just put the screws back in and fill with water.
If your looking from the back of the pump and the leak is between the motor and seal plate of pump then it has a bad seal and will need to be replaced. For this you seperate the half's of the pump by takeing the band clamp off pulling the front from the back then remove the five screws on the defuser pull it off if there is a screw in the center of the impeller, that is left handed and unscrews by turning clockwise. then unscrew the impeller and replace the seal. Reassemble pump with new "O" rings and fill with water.
Sta Rite 1 Hp... | Answered on Sep 03, 2009
You have to adjust the pressure switch to sense 45 PSI. Turn the adjustment CW just a bit and try it. Then adjust as needed.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Sta Rite 1 Hp... | Answered on Sep 01, 2009
You need to get to the shaft at the back of the motor to hold it while you use water pump pliers or the like to turn it off. It will unscrew in the regular direction but if it has a set screw to hold it in (You will find this at the center of the impeller) this will be a left hand screw so you will go clockwise to loosen it. This should get the impeller off. If not you will need to put a screwdriver in the side of the impeller and give it a hit to lossen the impeller. Good luck.
Sta Rite 1 Hp... | Answered on Aug 25, 2009
Sta Rite 1 Hp Above Ground Pump  Ne641 Logo
24 questions posted
Top Sta Rite Garden Experts
roeb
john h
Marvin
Marvin
Are you a Sta Rite Garden Expert? Answer questions, earn points and help others
View Most Popular
Sta Rite Garden
  • Sta Rite Garden
Most Popular Question
sta rite
  • Garden
